CaptainThrills
GPIO Pins just will not work
Fri Feb 05, 2016 2:53 am
I have tried quite a bit over these past few hours trying to get a simple LED to light up to no avail.
Plugging into the 3.3v worked, but GPIO pins just will not work for whatever reason. WiringPi & Python just won't work.
pin I'm using
| 18 | 1 | OUT  | GPIO. 5 | 5   | 24  |
commands I've tried:
gpio write 5 1
gpio write 5 0
which updates the readall, but it doesnt seem to be working.
Python Code I've tried
import RPi.GPIO as GPIO
import time
pin = 18
delay = 1
GPIO.setmode(GPIO.BOARD)
GPIO.setup(pin, GPIO.OUT)
def doLED(delayit):
        print("on")
        GPIO.output(pin, GPIO.HIGH)
        time.sleep(delayit)
        print("off")
        GPIO.output(pin, GPIO.LOW)
        return;
doLED(delay)
GPIO.cleanup()
Pi:
Raspberry Pi Details:
  Type: Pi 2, Revision: 01, Memory: 1024MB, Maker: Embest
Someone save me from this madness
rzusman
Re: GPIO Pins just will not work
Fri Feb 05, 2016 4:22 am
Have you tried setting the pin from the command prompt?
# gpio mode 5 out
# gpio write 5 1
# gpio write 5 0
See if that flips your LED.
gordon77
Fri Feb 05, 2016 4:27 am
Do you get any errors from the Python script?
You aren't passing pin to the def.
Return doesn't need the ;, try return or return()
CaptainThrills
Fri Feb 05, 2016 5:07 am
rzusman wrote:Have you tried setting the pin from the command prompt?
# gpio mode 5 out
# gpio write 5 1
# gpio write 5 0
Forgot to say that yes, I tried setting gpio mode to out.
gordon77 wrote:Do you get any errors from the Python script?
Heres new code, still not working (running as sudo python as well):
import time
pin = 18
delay = 1
def doLED(pin, delayit):
        print("on")
        time.sleep(delayit)
        print("off")
        return
doLED(pin, delay)
GPIO.cleanup()
Appears that a simple bash script has no issue accessing GPIO:
#!/bin/sh
x=0
while true; do
	if [ $x -ge 10 ]; then
		break;
	fi
	x=$((x + 1))
	echo "on"
	echo 1 > /sys/class/gpio/gpio18/value
	sleep 1
	echo "off"
	echo 0 > /sys/class/gpio/gpio18/value
	sleep 1
done
mattmiller
Fri Feb 05, 2016 6:44 am
unfortunately gpio18 is not the same as physical pin 18
https://superpiboy.files.wordpress.com/ ... pinout.jpg
If you want to use the gpio numbering scheme - change
to
GPIO.setmode(GPIO.BCM)
gordon77
Fri Feb 05, 2016 7:34 am
Nothing wrong with your new python code, lights a led on pin 18 (not GPIO18) on my pi.
Can you upload a photo of your wiring ?
CaptainThrills
Fri Feb 05, 2016 3:46 pm
Heres the circuit wiring
joan
Fri Feb 05, 2016 3:49 pm
A common problem with cobblers is to fit the ribbon cable reversed so pin 1 becomes pin 40.
Do you have a meter? If so check that the cobbler pin marked 3V3 supplies 3V3 and the cobbler pin marked 5V supplies 5V.
gordon77
Fri Feb 05, 2016 3:59 pm
I'd say that's GPIO #18 (pin 12) NOT PIN 18 (GPIO #24)
Change your python to pin = 12, or GPIO.BCM
JimmyN
Fri Feb 05, 2016 4:26 pm
I have 2 cobblers and on both the numbers printed on the cobbler are BCM numbers, not BOARD numbers.
With bash you were changing "gpio 18", which is a BCM number and matches #18 on the cobbler, which is also a BCM number. So it works.
The Python script is setting the mode to BOARD so it doesn't work, since #18 on the cobbler is a BCM number. If you're going to use BOARD number 18 in Python then you'll need to plug into #24 on the cobbler, since BOARD #18 is BCM #24.
The simplest way is to set the mode to BCM in Python, then you can use the numbers printed right on the cobbler without having to convert BOARD numbers to BCM numbers.
CaptainThrills
Fri Feb 05, 2016 4:47 pm
Thanks all, this makes everything a bit more clear now. Changing it to GPIO.BCM did the trick for the python script.
gordon77
Fri Feb 05, 2016 5:34 pm
It's easy to get confused and mix-up the 2 numbering schemes.
