ketochka
Headless connection with a laptop - please help to set up
Fri Jan 29, 2016 3:08 pm
Can you please help me,
I have Raspberry PI model B and I set up it for the first time.
I don't have a monitor, neither a usb keyboard, so I need to connect it to my laptop through headless connection.
I used these how-to: https://www.youtube.com/watch?v=Ioih6MHNNqc and https://pihw.wordpress.com/guides/direc ... onnection/
I set ip address for Raspberry PI 169.254.1.1 and my laptop has no fixed IP (set up automatically).
(I have Linux Mint)
It can't set up direct connection -- I mean no network connection.
Can you please advice me what should I do to set it up?
mattmiller
Re: Headless connection with a laptop - please help to set u
Fri Jan 29, 2016 11:51 pm
Try adding
auto eth0
iface eth0 inet
static address 169.254.1.2
netmask 255.255.0.0
into /etc/network/interfaces on your Linux machine
ketochka
Fri Jan 29, 2016 11:57 pm
Thank you, I planned to use ssh, but at first I need just to set up a network connection, for now it doesn't work
rurwin
Sat Jan 30, 2016 12:08 am
The best way to set up a static IP address is to set it on your router. That way if you ever take the RaspPi away from home it will still work. If you set it on the RaspPi and you put it on a different network, you won't be able to talk to it.
Also, of course, it has to be wired Ethernet. Until you configure the SSID and password you can't use WiFi.
Are you using Raspbian? If so, ssh should just work; there's nothing to do to enable it. If you are using NOOBS, then I don't believe you can boot it headless the first time.
ketochka
Sat Jan 30, 2016 12:29 am
Yeah, I use Raspbian and I use wired Ethernet connection: Raspberry PI - laptop.
The thing is -- I don't have an access to the router.
I understand that if I take it somewhere else with these IP settings, it wouldn't work.
ketochka
Sat Jan 30, 2016 12:40 am
mattmiller wrote:Try adding
auto eth0
iface eth0 inet
netmask 255.255.0.0
I tried it, aslo tried with a closer mask: 255.255.255.0, but nothing. (I tried rebooting as well)
Anyway, thank you.
mattmiller
Sat Jan 30, 2016 12:47 am
JFI You should be using 255.255.0.0 for 169.254.xxx.yyy addresses
mattmiller
Sat Jan 30, 2016 12:48 am
What does ifconfig show on your Linux machine with Pi plugged in then ?
mattmiller
Sat Jan 30, 2016 12:49 am
How/where have you setup your Pi for 169.254.1.1 ?
Please paste the file here :)
ketochka
Sat Jan 30, 2016 12:56 am
Here are both files
files.zip
(329 Bytes) Downloaded 29 times
mattmiller
@rurwin - I think you mis-read the OP
Well I call it reserved addressing not static when you do that on a router but tomato tomato :)
em yes but that's not what the OP is trying to do
he is just trying to use link-local Ip addressing between a machine and a Pi - similar to my request for static fallback viewtopic.php?f=66&t=134138&p=895278#p895278
mattmiller
Sat Jan 30, 2016 12:57 am
I'm getting an error trying to open your zip :(
ketochka
Sat Jan 30, 2016 1:05 am
once again
files.tar.gz
(370 Bytes) Downloaded 27 times
ketochka
Sat Jan 30, 2016 1:11 am
And here's my ifconfig:
ketka@ketka:~ > ifconfig
eth0 Link encap:Ethernet HWaddr b8:88:e3:3b:03:e9
inet6 addr: fe80::ba88:e3ff:fe3b:3e9/64 Scope:Посилання
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
Прийнято пакунків:37 помилок передачі:0 пропущено:0 перерозхід:0 кадри:0
TX packets:275 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
Прийнято байтів:10489 (10,4 KB) Передано байтів:56650 (56,6 KB)
lo Link encap:Локальна петля (Loopback)
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Хост
UP LOOPBACK RUNNING MTU:65536 Metric:1
Прийнято пакунків:1075 помилок передачі:0 пропущено:0 перерозхід:0 кадри:0
TX packets:1075 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
Прийнято байтів:91388 (91,3 KB) Передано байтів:91388 (91,3 KB)
wlan0 Link encap:Ethernet HWaddr c0:14:3d:dc:32:c3
inet addr:192.168.0.102 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::c214:3dff:fedc:32c3/64 Scope:Посилання
Прийнято пакунків:4989 помилок передачі:0 пропущено:0 перерозхід:0 кадри:0
TX packets:5024 errors:0 dropped:0 overruns:0 carrier:0
Прийнято байтів:1829651 (1,8 MB) Передано байтів:1510792 (1,5 MB)
it's with ukrainian language, but the idea is: only errors in transmitting and no IPv4 is shown on eth0
stderr
Sat Jan 30, 2016 1:21 am
auto eth0
iface eth0 inet
netmask 255.255.0.0
Anyway, thank you.
It's not clear to me what you are doing that isn't working. When you supposedly boot the pi, are you then going to the windows machine and attempting to ping the pi with the supposed address it has? I just tested this with 169.254 addresses on Ubuntu and Raspian Wheezy and they just automatically are there. How do you know that the pi has booted if you are headless?
mattmiller
Sat Jan 30, 2016 1:23 am
Well we need to get your Linux machine to set the IP
try this in /etc/network/interfaces instead of my earlier suggestion
iface eth0 inet static
address 169.254.1.2
netmask 255.255.0.0
mattmiller
Sat Jan 30, 2016 1:26 am
no 1 - He's using Linux Mint on other computer - not windows
Lots of Linux machines don't default to a 169.254 address (they should - but they don't) :(
So he needs to force static on Linux Mint 1st before we get into what's happening on Pi
ketochka
Sat Jan 30, 2016 1:33 am
Oh, now eth0 just dissapeared.
________________________
And here's what in interfaces.txt:
# interfaces(5) file used by ifup(8) and ifdown(8)
address 169.254.1.2
netmask 255.255.0.0
___________________
Прийнято пакунків:579 помилок передачі:0 пропущено:0 перерозхід:0 кадри:0
TX packets:579 errors:0 dropped:0 overruns:0 carrier:0
Прийнято байтів:46495 (46,4 KB) Передано байтів:46495 (46,4 KB)
Прийнято пакунків:629 помилок передачі:0 пропущено:0 перерозхід:0 кадри:0
TX packets:821 errors:0 dropped:0 overruns:0 carrier:0
Прийнято байтів:187429 (187,4 KB) Передано байтів:122536 (122,5 KB)
mattmiller
Sat Jan 30, 2016 1:35 am
try
ifup eth0
from terminal
mattmiller
Sat Jan 30, 2016 1:37 am
If that works try this in /etc/network/interfaces
auto eth0
address 169.254.1.2
netmask 255.255.0.0
ketochka
Sat Jan 30, 2016 1:39 am
ketka ketka # ifup eth0
ifup: interface eth0 already configured
ketka ketka #
ketochka
Sat Jan 30, 2016 1:43 am
oh, yeah!
you are a master!
it works :)
Thank you so much,
and wish you all the best.
