Transmission won't install from OSMC/Kodi programs menu
Posted: Thu Jan 28, 2016 4:25 pm
I'm attempting to install Transmission from the Kodi/OSMC programs menu.
I'm on a fresh install of OSMC.
I try to launch Transmission after running (from the Programs menu), however it gives me the error: "Could not connect to Transmission. Open settings dialog?" I run this:
but it tells me it isn't even installed, which is weird.
I have the defaults in host and port set, and then in user/pass I have the default "transmission/transmission".
I've installed Transmission successfully from the cmd prompt, but this appstore version is not working. Anyone know what might be the problem, or at least where to start troubleshooting?
sudo systemctl status transmissionI have the defaults in host and port set, and then in user/pass I have the default "transmission/transmission".
