chleo
failed to change RPi hostname
Wed Jan 27, 2016 2:52 pm
when i try to change the host name of a new RPi, i meet a strange issue, can anyone help me on this?
this happens on new RPi which installed the latest NOOBS (ver:1.5.0), for my old one, no such issue:
1. sudo nano /etc/hostname
rpi_new_name
2. sudo nano /etc/hosts
127.0.1.1 rpi_new_name
3. sudo reboot
after rebooting, i see the prompt is changed to
but above two config files have been changed back, that means my modifications are lost.
then, i noticed RPi will automatically reboot and back to
thanks in advance,
Leo
klricks
Re: failed to change RPi hostname
Wed Jan 27, 2016 3:05 pm
Your hostname is not valid. It can't have _ or any other punctuation except for a '-'
raspi-confg does warn you about that but will not stop you from entering an invalid hostnarme.
When you have entered an invalid hostname and then attempt to change it, then raspi-config gets confused and does not parse correctly.
You will need to edit the 2 hostfiles and manually put in a valid hostname to fix it
asandford
Wed Jan 27, 2016 11:04 pm
To change the hostname involves more than just editing that file.
To change the hostaname properly use
sudo raspi-config
select option 8 (advanced options), then option A2 hostname.
chleo
Thu Jan 28, 2016 5:16 am
thanks for all replies.
i know it is convenient to use
sudo raspi-config
, but i am looking for another solution so that i can use python script automatically config RPi's name...
chleo
Thu Jan 28, 2016 5:20 am
klricks wrote:Your hostname is not valid. It can't have _ or any other punctuation except for a '-'
sorry for misunderstanding, here i use "rpi_old_name" just for an example.
chleo
Thu Jan 28, 2016 5:49 am
asandford wrote:To change the hostname involves more than just editing that file.
sudo raspi-config
and i have to say i find this issue too when using
sudo raspi-config
to change the host name.
klricks
Thu Jan 28, 2016 6:37 am
chleo wrote:...
sudo raspi-config
I am running Raspbian Jessie (not installed with NOOBS)
I just changed my hostname manually by editing /etc/hosts and /etc/hostname and I also tried sudo raspi-config and did not have any problem changing the hostname with either method.
Thu Jan 28, 2016 6:54 am
You should be able to change the name, either by editing those files, or by using raspi-config. I did it yesterday on a new Raspbian Jessie install.
Are you using a standard Raspbian setup (perhaps from NOOBS), or something else?
chleo
Thu Jan 28, 2016 7:44 am
:( this new RPi uses the latest NOOBS (ver:1.5.0)
Thu Jan 28, 2016 7:47 am
Yes, I understand that you have the NOOBS installer. But which OS did you install from the first menu?
chleo
Thu Jan 28, 2016 8:42 am
one more thing:
after modifying host files, and run "sudo reboot", i saw the first message scrolling over screen is:
sudo: unabale to resolve host rpi-old-name
Thu Jan 28, 2016 12:10 pm
chleo wrote:one more thing:
That's because you've removed the entry from the /etc/hosts file, so there's no way the resolver can find a valid IP address for your old name.
This is a doctor free zone.
chleo
Thu Jan 28, 2016 12:42 pm
rpdom wrote:Yes, I understand that you have the NOOBS installer. But which OS did you install from the first menu?
$ uname -a
Linux CNb827eb3686f6-Cactus 4.1.13+ #826 PREEMPT Fri Nov 13 20:13:22 GMT 2015 armv6l GNU/Linux
"CNb827eb3686f6-Cactus" is rpi-old-name, e.g. i plan to change it to be "CNb827eb3686f6-Leo", but failed :(
chleo
Thu Jan 28, 2016 12:47 pm
DougieLawson wrote: That's because you've removed the entry from the /etc/hosts file, so there's no way the resolver can find a valid IP address for your old name.
thanks for your answer.
i am sure "rpi-new-name" in /etc/hosts and /etc/hostname are exactly same, so what could be the reason?
Thu Jan 28, 2016 12:56 pm
Whenever you change hostname you need to reboot.
chleo
Thu Jan 28, 2016 3:02 pm
DougieLawson wrote:Whenever you change hostname you need to reboot.
yes, i do reboot up rpi.
actually after booting up, the prompt uses the NEW name.
but when i nano /etc/hosts and /etc/hostname files, they still contain OLD name.
then, after a while, rpi will reboot automatically, and change back to OLD name.
might this relate with DNS resolve setting?
chleo
Fri Feb 19, 2016 6:49 am
post a solution here:
besides modify above 2 host files, i run
sudo hostnamectl set-hostname xxx
fsr
Fri Feb 19, 2016 9:20 am
sudo hostname new-hostname
changes the hosts name immediately (but not permanently). Couple it with the appropriate changes to /etc files to change the hostname without a reboot.
dgordon42
Sat Feb 20, 2016 1:32 am
Not sure if this is part of the problem, or just the way it's written, but chleo wrote above:
/etc/hosts and /etc/hostsname are owned by root, so if you don't use 'sudo nano', the changes won't get written out to the files on the SD card, and so they will appear to revert back to the old name by themselves.
Dave.
janpihlgren
Wed Jan 31, 2018 6:42 am
I also have failed to change hostname.
Oldname = Caecilius
Newname = Caracall
I tried to do : sudo nano /etc/hostname and change the name. Then I did: sudo nano /etc/host and change the name for 127.0.0.1
I also tried sudo hostnamectl set-hostname Caracall
After that I did sudo reboot
The Oldname still there, no change done.
uname -a gives: Linux Caecilius 4.4.34+ #930 Wed Nov 23 15:12:30 GMT 2016 armv6l GNU/Linux
When i logged in again I get the followng message:
Permissions 0744 for '/home/jan/.ssh/id_rsa' are too open.
It is required that your private key files are NOT accessible by others.
This private key will be ignored.
Load key "/home/jan/.ssh/id_rsa": bad permissions
[email protected]_wifi's password:
For me it looks like that the oldname is save somewhere else and then used at logg in.
Is there anyone that know where to look for this odd behavieour?
dgordon42
Wed Jan 31, 2018 6:57 pm
Post the output of:
cat /etc/hostname
cat /etc/hosts
Dave.
janpihlgren
Thu Feb 01, 2018 5:21 am
[email protected]:~ $ cat /etc/hostname
Caecilius
[email protected]:~ $ cat /etc/hosts
127.0.0.1 localhost
::1 localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
127.0.0.1 Caecilius
10.0.0.6 Bubba
10.0.0.38 Commodus_wifi
10.0.0.100 Zebbie
This is the result after changed the name to Caracalla and rebooted.
dgordon42
Thu Feb 01, 2018 8:41 am
It appears that the changes you make to the '/etc/hosts' and '/etc/hostname' files are not being written to your SD Card, and so when you reboot the old values return.
This could indicate that your SD Card has gone "Read Only", one of the signs of an SD Card failure.
Burn a fresh copy of Raspbian onto a genuine good quality SD Card, and try again.
Hope this helps,
Dave.
janpihlgren
Thu Feb 01, 2018 8:59 am
When I chaqnge the hostname, save the change and then read /etc/hostname the change is as supposed.
I then write a textfile and saved it and the reboot the file is gone.
So it looks like that you are right.
To use a new SD-card isn't the option.
How do I do to get the card writeable again?
Thu Feb 01, 2018 9:46 am
You can't it's reached end-of-life and is just trash now.
