AEM
Re: Pi Zero USB does not work at all
Sun Jan 31, 2016 4:03 pm
I have the same exact issue. I've tried with and without a hub, with wireless mouse, wired mouse, wireless keyboard mouse combo but to no avail. I have a decent power supply (5V 2.5A) that works perfectly with my RPi 2. Is there any way to go about getting a replacement?
Thanks.
Onira
Sat Feb 13, 2016 6:46 pm
my RPi0 boots up to desktop I can see it via connected HDMI but no USB devices do work
Cogito ergo sum
koboldthegreat
Tue Mar 01, 2016 6:15 pm
I'm also having problems with my raspberry pi zero I received yesterday. Just as you, everything's working except the usb OTG. I measured the pads, got 3.3 on D+, D- and 5V on the power. Is there a possibility to return the pi to the manufacturer, and get a replacement one?
kobold
themaire
Mon Mar 21, 2016 9:10 pm
Hello guys, welcome to the club.
viewtopic.php?f=28&t=139169
I have the same problem too. I imagine The Mag Pi don't replace the "gift". It is a bad raspberry tast this Zero.
Bye from France.
All my Raspberry Pi stuffs on my Twitter : @nico_themaire
:D
djbottrill
Fri Mar 03, 2017 4:01 pm
Me too and I paid good money to the PI Hut for mine.
Fri Mar 03, 2017 4:13 pm
Anyone who bought them from supplier - they are under warrantee - talk to the people you got them from.
Not sure what the deal is on ones from the Magpi.
That said, these things are generally very reliable and tested before they are sent from the factory, so might be worth trying to figure the problem before sending them back.
(Note, 500k Zero's have been sold, and the reliability rate is extremely high)
Fri Mar 03, 2017 4:16 pm
So, some troubleshooting...
Plug in the OTG adapter to the USB port (not the power port). Boot the Pi.
What does `lsusb` show?
Attach a mouse (or similar) - anything happen?
MrEngman
Fri Mar 03, 2017 4:29 pm
jamesh wrote:So, some troubleshooting...
Not so easy when most are saying the USB is not working so cannot get a keyboard to work.
But as you suggest plug in an OTG adapter rather than an ordinary micro B cable, which I suspect is likely to be the problem, and then I would expect it to work.
MrEngman
Fri Mar 03, 2017 4:42 pm
MrEngman
Ahh, good point, I was thinking non-Zero.
Fri Mar 03, 2017 4:52 pm
MrEngman
One can check if Zero is dead by following procedure outlined in this post:
viewtopic.php?f=28&t=58151#p850218
adieu
My other Computer is an Asus CS10 ChromeBit
Paul Webster
Contact: Twitter
Fri Mar 03, 2017 6:17 pm
I had to bend up the pins inside the USB to get one of mine to work reliably.
By comparing the two sockets I could see that the USB one was out of alignment.
Iturnem
Tue May 16, 2017 12:23 am
Just a tip for those having trouble finding a hub that works. I went through trying one powered and one non powered hub not working and then decided to try the one for Rockband for Nintendo Wii and it works perfectly
adem
Fri Nov 16, 2018 3:55 pm
I had the same problem, here is what I do:
Connect to the Pi using SSH
Run:
sudo apt-get update
sudo apt-get upgrade
While Pi install upgrades follow the shell, it anything not install because of your internet connection run the commands above again.
Then reboot using:
reboot
Happy safe hacking :smile:
[1]: https://www.raspberrypi.org/documentati ... ccess/ssh/
