How do I upload a picture
It says the file is too big
I'm on an iPad
Only after you've first learned to de-solder. Breadboards are extremely useful for short term experiments, soldering should be considered permanent. Suggesting to the new users that they shouldn't use a breadboard is irresponsible.GTR2Fan wrote:Breadboard is the work of the devil. Learn to solder.
As is selling breadboard to beginners without concise instructions on how to use it due to the permanent damage it can do to attached hardware and the user if used incorrectly.DougieLawson wrote:Suggesting to the new users that they shouldn't use a breadboard is irresponsible.
The plain perforated board (ie, no copper tracks) is far more sensible as it's not magically putting connections in where you almost certainly don't want them. Either that or just bird's-nest it if it's a simple circuit with few components. Both allow circuits based largely on discrete components to be laid out in very much of a like-for-like fashion in relation to circuit schematics, so potentially dangerous mistakes are far less likely to happen.Burngate wrote:That seems to imply the use of a circuit board of some sort.
The only circuit board I know of that isn't special-purpose is stripboard, aka Veroboard.
