Yes"Is there a simple method on Linux that lets you write an image to the SD card and be done with it like you do with ISO images to CDs? "...
Noobs Lite will still want to download large files...QuietZone wrote:You guys are, as usual, all missing the point.
The OP is having problems downloading large files. Thus, any "solution" that involves downloading a large file is a non-starter.
"I gave up and turned on my old windows computer that allowed me to download the zip file. I installed the SD format program formatted the 8 Meg SD card unzipped the NOOBS and copied the files to the SD card but half way through disaster struck again. The root.tar.xz file under the operating system would not be copied."QuietZone wrote:You guys are, as usual, all missing the point.
7ZIP unzipper is better than the one built into Windowsgordon77 wrote:"I gave up and turned on my old windows computer that allowed me to download the zip file. I installed the SD format program formatted the 8 Meg SD card unzipped the NOOBS and copied the files to the SD card but half way through disaster struck again. The root.tar.xz file under the operating system would not be copied."QuietZone wrote:You guys are, as usual, all missing the point.
Not sure the 'as usual' applies. If they were able to download the file and unzip it, did that imply it was a download problem?
This is exactly the point. I was being semi-facetious when I mentioned there being a download limit. I was trying to avoid hurting your feelings.I think it is just one of those when there are bad vibrations in the ether.
I find unzip in Win10 is fine.fruitoftheloom wrote:7ZIP unzipper is better than the one built into Windowsgordon77 wrote:"I gave up and turned on my old windows computer that allowed me to download the zip file. I installed the SD format program formatted the 8 Meg SD card unzipped the NOOBS and copied the files to the SD card but half way through disaster struck again. The root.tar.xz file under the operating system would not be copied."QuietZone wrote:You guys are, as usual, all missing the point.
True you can't unzip with win XP, you need Win10 or 7zip l believe.Ruptor wrote:I brought the NOOBS zip file with me and unzipped it under Linux then copied it to the SD card, overwriting the half copied file system done on windows, without a problem. Clearly there is nothing wrong with the file it has to be a problem with Windows XP. So I ask the question again has anybody actually tried the instructions because it looks like my version of windows can't handle the large 1 GB file copy to SD.
You joined here about a month ago and claim that all the people providing good support here for years are all wrong. You should reconsider your attitude.QuietZone wrote:You guys are, as usual, all missing the point.
Sounds like the departed JScohme or whatever is name wasgkreidl wrote:You joined here about a month ago and claim that all the people providing good support here for years are all wrong. You should reconsider your attitude.QuietZone wrote:You guys are, as usual, all missing the point.
It worked for me using XP SP3.Ruptor wrote:Clearly there is nothing wrong with the file it has to be a problem with Windows XP. So I ask the question again has anybody actually tried the instructions because it looks like my version of windows can't handle the large 1 GB file copy to SD.
Apologies l was thinking of the raspbian download not noobs.hippy wrote:It worked for me using XP SP3.Ruptor wrote:Clearly there is nothing wrong with the file it has to be a problem with Windows XP. So I ask the question again has anybody actually tried the instructions because it looks like my version of windows can't handle the large 1 GB file copy to SD.
I had already downloaded NOOBS_v1_5_0.zip but had not actually tried using it. I used WinRar to extract the contents, then just dragged and dropped the extracted files using Windows Explorer to a previously unused 8GB SDHC using an external 'Poundland' USB card writer.
No problems or issues at all while doing any of that.
I used WinRar because people had reported Windows has a problem with the file size / compression type, but when I just tried it the Windows way ( right-click on the .zip, then Extract All ), it seemed to work and all the files appear to be there and the right size.
I also tried with an old version of WinZip and that seems to have had no problems either.
No need to apologise and I wasn't having ago. It could well be Raspbian which has problems being unzipped. I just noted in passing there was a some issue raised so I used WinRar when I downloaded NOOBS to get Jessie, it worked so I stuck with that and never tried with anything else.gordon77 wrote:Apologies l was thinking of the raspbian download not noobs.
You can force output on boot, it is in readme:Ruptor wrote:Hi Hippy
The problem is in the copying of files from the hard disk to the SD. The instructions say drag and drop but it stops on the 1GB file transfer for me having already written some files to the SD.
I have a new problem now. After NOOBS installed and I clicked OK the screen went blank and nothing happened. Now when I turn on the RPi the video gets a couple of fast white bars across it but nothing else. When NOOBS first came up I was asked if I want composite video as default and I said yes. I assumed it would be added to the install when it was finished but it doesn't look like it. Any suggestions?
