two months ago is too long, as the Zero was launched just over a month ago! A Zero works only with versions of NOOBS (which I recommend using instead of using DD to burn images) released AFTER the launch of the Zero which is obvious if you know that this version of the PI uses a new brand of RAM (package on Package chip) so it needs new boot packages, just as previous incarnations that used a new RAM type also need new software, because the PI has no setup/BIOS code built in, to catch the differences.r.c.carroll wrote:All cards, except one Pidora were created within the last two months, all from current versions downloaded that day.
IMO carrying or handling the RPi or any other type of circuit card with exposed circuitry AND not taking ESD (anti static) precautions would be a destructive or unsuitable environment.r.c.carroll wrote:..............
You say if I use the Zero in "an environment that is unsuitable for it," but carrying the Pi Zero around seems like a natural for it's size. I had no idea that carrying around a Zero would be considered an unsuitable environment. I work a lot with Scouts, and consider the RPi to be a nice way to augment the program.
The first point of call is the Microcentre - take it to them, and see if they can get it to boot. If they cannot, it's broken, so you should be refunded. Surely Illinois has regulations to mean if you are sold a broken device you are refunded?r.c.carroll wrote: Likely the most troubling, I purchased this 11/26/15, which is 6-1/2 weeks ago, and still don't have an answer as to how to proceed. The store flatly refuses to help, the foundation also refuses, the Trading company won't answer questions, so I come to the forums here seeking help. I read your answer and don't see where it helps me at all. I have already tried what you asked, I it tried again, and it still doesn't work. Insanity is defined as trying things over again the same way, and hoping for a different result.
It's that kind of attitude which has people like the OP getting rather frustrated to say the least.mahjongg wrote:if that doesn't help the only sane thing is to throw the zero away..... 5$ is not worth frustrating over.
and yes, chances are 99 to 1 that you are doing something wrong, sorry.
And the refund can only come from the person he purchased it from. Microcentre. As I said in the previous post, go to Microcentre, ask them to get it working, if they fail, ask for money back.hippy wrote:It's that kind of attitude which has people like the OP getting rather frustrated to say the least.mahjongg wrote:if that doesn't help the only sane thing is to throw the zero away..... 5$ is not worth frustrating over.
If I get a product which has a manufacturing fault I expect it to be replaced or at least my money refunded. There is nothing unreasonable in that.
Agreed, but if the place where you bought it refuses to refund you, what do you expect me to do about it ? Why is he complaining here, I'm willing to help him with booting, but with some people no amount of assistance seems to help.hippy wrote:It's that kind of attitude which has people like the OP getting rather frustrated to say the least.mahjongg wrote:if that doesn't help the only sane thing is to throw the zero away..... 5$ is not worth frustrating over.
Learn something new everyday heregregeric wrote:You can use the Zero's USB boot capability as a diagnostic for dead or not, before going on to investigate SD card issues:
Take your bare naked Zero, no cables or cards in any slot or socket. Take a normal micro-USB to USB-A cable (the most common type) & connect it to your PC, plugging the micro-USB into the Pi's data USB nearest the HDMI, not the PWR_IN. If the Zero is alive, within a few seconds your Windows PC will go chime for the presence of new hardware & you should see "BCM2708 Boot" in Device Manager. On linux, a similar message from dmesg. If you see that, so far so good, you know the Zero's not dead.
Now you can go on to investigate SD issues, or return the dead Zero.
[ 48.656033] usb 2-2: new full-speed USB device number 2 using uhci_hcd
[ 48.824749] usb 2-2: New USB device found, idVendor=0a5c, idProduct=2763
[ 48.824755] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 48.824759] usb 2-2: Product: BCM2708 Boot
[ 48.824762] usb 2-2: Manufacturer: BroadcomTo be honest, it's not a matter of what you expect, it's a matter of what law's provisions are.hippy wrote:If I get a product which has a manufacturing fault I expect it to be replaced or at least my money refunded. There is nothing unreasonable in that.
DId the private solution get it working?r.c.carroll wrote:I no longer own the Pi 0. Actually the moderator was close to right, I should just discard it, and stop trying to fix a $5 computer. Unfortunately, I don't throw computer boards in the trash, they go electronic recyclers due to the way they make PCBs. That meant, I would have to take it somewhere to get rid of it. We found a nice, private solution that all parties are happy with.
It rarely is.r.c.carroll wrote:Well, I guess what my grandson told me was not correct.
