JOHNBOY44
RS232 interface logon disable
Wed Aug 01, 2012 8:45 am
I am trying to use the RS232 I/O port to read/write from a 'C' program. Output works fine but reading data appears to be inhibited by Linux sending logon username & password messages after a CR character is entered.
Is there a way of dissabling the system logon at the ttyAMA0 port?
I have tried both Squeeze and Wheezy versions - both do this.
Thanks JOHNBOY44
nroff-man
Re: RS232 interface logon disable
Wed Aug 01, 2012 9:11 am
lo
look at /etc/inittab
specifically the line with getty -L ttyAMA0
read the man page for getty, look at the
-l option.
change that line to run /bin/bash
instead of login
send a HUP to PID 1 and it should work
bye
jdbennet
Wed Aug 01, 2012 9:12 am
Remove the "console=ttyAMA0...." lines from cmdline.txt, and also remove mention of it from /etc/inittab and /etc/securetty, this will stop terminals being spawned on it.
JOHNBOY44
Sun Aug 05, 2012 1:34 pm
Thanks for your suggestions - commenting-out the getty line in /etc/initab has solved the problem for me.
JOHNBOY44
