Highlow9
Transmission daemon doesn't start on boot
Wed Dec 30, 2015 9:35 pm
Hello
When i reboot my pi (2b with raspbian) my transmission-daemon doesn't seam to start. When i try to connect via web i get this message http://i.imgur.com/J80zRgi.png . But when i enter (on the pi) 'sudo service transmission-daemon reload' it works.
Setup
Pi 2 model b
16 gb sd (fat 32)
raspbian (via noobs)
external (3tb ntfs) hard drive
Tutorials followed :
http://pimylifeup.com/raspberry-pi-torrentbox/
Trouble shooting already done :
http://raspberrypi.stackexchange.com/qu ... at-startup (this guy seams to be having the same problem as me)
dentex
Re: Transmission daemon doesn't start on boot
Fri Jan 08, 2016 8:03 am
Hi, just as a reference:
https://forum.transmissionbt.com/viewto ... 605#p72605
and
https://trac.transmissionbt.com/ticket/5737
If you want an awful fix (that anyway works), do:
sudo nano /etc/init.d/transmission-daemon-reload
Put inside:
#!/bin/sh
### BEGIN INIT INFO
# Provides: transmission-daemon-reload
# Required-Start: $all
# Required-Stop:
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Reload the transmission-daemon
# Description: Reload the transmission-daemon at boot.
### END INIT INFO
NAME=transmission-daemon-reload
sleep 10
Save the init.d script and make it executable.
Then do:
sudo update-rc.d transmission-daemon-reload defaults
Reboot and check it.
Basically it's just an ugly "sleep" hack.
One of my projects with the Raspberry Pi:
(Raspberry) Pi Aquarium Controller: https://github.com/dentex/piac
malicious
Fri Jan 08, 2016 10:39 am
This workaround from the Arch Linux wiki may also help:
https://wiki.archlinux.org/index.php/Tr ... rt_at_boot
/etc/systemd/system/transmission.service.d/fixdep.conf:
[Unit]
Requires=network.target
dentex
Fri Jan 08, 2016 11:18 am
malicious wrote:This workaround from the Arch Linux wiki may also help...]
transmission-daemon's script in /etc/init.d already has Required-Start: $network in its INIT INFO header.
The problem seems that the "network is up" notification by the system it's a bit buggy: https://trac.transmissionbt.com/ticket/5737
zamus
Sun Feb 10, 2019 3:49 am
After hours of tests i finnaly found a solution that worked for me.
I'm writting this here because may be help other people on the future.
My issue, is the transmission daemon don't autostart on boot, but if i start the service manually work well.
After reboot the command: netstat -lntp
is helpful in order to see if you have the port 9091 on the list, when works you see that port on the list, if not something else is broken.
Run this command:
sudo systemctl status transmission-daemon.service
You should see something like this this:
transmission-daemon.service - Transmission BitTorrent Daemon
Loaded: loaded (/lib/systemd/system/transmission-daemon.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2019-02-10 03:33:45 UTC; 7min ago
Probably you see the service disabled and inactive.
So do this:
Edit the file /etc/default/transmission-daemon with your favorite editor
Look for this line:
ENABLE_DAEMON=0
and change the 0 to 1
ENABLE_DAEMON=1
Save the file.
Then run:
sudo systemctl enable transmission-daemon.service
Reboot and run the
and look for the active (running)
and run netstat -lntp
and look for
tcp 0 0 0.0.0.0:9091 0.0.0.0:* LISTEN 834/transmission-da
That's mean the deamon auto-started on boot.
