I have a model B running wheezy. Have just updated the kernel from 3.12 to 4.1.15 and updated all packages. I now see from atop that it's running at 800MHz (100%) most of the time, even when 90% idle. Previously it was usually 700MHz with the occasional foray to 800MHz (100%) under load.
It's running as a tvheadend server with wifi and an external usb disk. tvheadend itself usually runs at about 10% cpu (since it's constantly scanning channels). Previously, I could be recording (20%) plus playing omxplayer (either locally or remotely via http), plus atop, and still be at 700MHz. It would jump to 800MHz if I was also doing a file transfer or something.
This is not necessarily a problem, but not what I expected. Has something changed in the way ondemand tunes itself ? Obviously, the very act of trying to read the frequency triggers activity which could be boosting it.
Apologies if this has already been discussed - I don't come here as often as I should.
$ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_{governor,cur_freq} /proc/loadavg
ondemand
800000
0.17 0.28 0.26 1/109 10780
$ while sleep 1 ; do cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq /proc/loadavg ; done
800000
0.17 0.28 0.26 1/109 10782
800000
0.17 0.28 0.26 1/108 10784
800000
0.15 0.28 0.25 1/109 10787
800000
0.15 0.28 0.25 1/109 10789
800000
0.15 0.28 0.25 1/109 10791
700000
0.15 0.28 0.25 1/109 10793
800000
0.14 0.27 0.25 1/109 10795
800000
0.14 0.27 0.25 1/109 10797
^C
