with ice cream
otus driver for wpa_supplicant?
Tue Jul 31, 2012 4:36 am
I found out that for getting my combination of my wifi stick TP-Link TL-WN821N and WPA2 working I need to use wpa_supplicant and the otus driver. Is this correct?
Do I need to compile the driver myself or is there another way? Any pointers are appreciated.
blakharaz
Re: otus driver for wpa_supplicant?
Tue Jul 31, 2012 10:26 am
You just need to load the ath9k module in order to get the card working.
To load the module on a running system run as su:
modprobe ath9k
And to load the module at startup you need to add this line to the file /etc/modules
ath9k
To use wpa_supplicant you need to write you network config in the config file and start it with:
wpa_supplicant -i wlan0 -c /path/to/config
As far as i know the default location is /etc/wpa_supplicant.conf.
