DaHai8
pre-up not running script
Tue Dec 22, 2015 1:08 pm
I this a script to open the firewall for OpenVPN:
#!/bin/sh
iptables -t nat -A POSTROUTING -s 10.8.0.0/24 -o eth0 -j SNAT --to-source 10.254.22.184
I have it in my /etc/network/interfaces file like so:
auto lo
iface lo inet loopback
iface eth0 inet manual
  pre-up /etc/open_vpn_firewall.sh
The script is set with
chmod 700 /etc/open_vpn_firewall.sh
chown root /etc/open_vpn_firewall.sh
I reboot the Pi and connect with OpenVPN client just fine. BUT I can't access any web pages...unless I manually execute the open_vpn_firewall.sh script on the Pi through SSH. Then everything works!
Any ideas what could be wrong? Why this doesn't seem to execute on startup?
P.S. I'm running Jessie Lite with updates/upgrades
Thanks!
chesty
Re: pre-up not running script
Tue Dec 22, 2015 5:28 pm
I think manual means the ifup command doesn't handle the interface,
so pre-up doesn't get run.
I don't know what brings the interface up though, you have a choice of finding out how the interface is brought up, and see if that has any hooks, or change the interface to dhcp and auto
DaHai8
Wed Dec 23, 2015 1:40 am
I tried auto and dhcp, still no joy :(
chesty
Wed Dec 23, 2015 2:06 am
I don't know then.
this isn't the problem, but will make it more bullet proof if your dhcp ip changes
change
to
iptables -t nat -A POSTROUTING -s 10.8.0.0/24 -o eth0 -j MASQUERADE
paste your full interfaces file now
DaHai8
Wed Dec 23, 2015 3:58 am
Thanks Chesty,
You're right, it didn't fix the problem, but it the 'MASQUERADE' does help with dhcp changes. :)
The thing that bugs me is that this used to work under Wheezy...
chesty
Wed Dec 23, 2015 11:54 am
this works for me
auto wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-ssid blah
wpa-psk blah
pre-up iptables -I INPUT -j ACCEPT
I'm running debian not raspbian, but there's not much different.
Grez
Sun Jan 03, 2016 6:16 pm
I've got exactly the same problem and a new Jessie-lite build, and this is works fine on my other pi with a previous Jessie build.
Did you ever find out what the problem was?
Cheers
Grez..
Grez
Sun Jan 03, 2016 8:35 pm
OK I've figured it out, I needed to add the below into the interface file.
auto eth0
So I now have the below in the interfaces file and this is working just fine.
auto eth0
  pre-up /etc/openvpnfirewall.sh
Cheers Grez..
mann
Thu Dec 01, 2016 8:26 pm
I had the same problem, auto eth0 solved it.
Someone care to explain this auto eth0 and why it didn't work before?
raygeeknyc
Sun Oct 08, 2017 9:49 pm
I've been wrestling with this mess for a while and found the following working solution
1) Run the script as a hook from dhcpcd, rather than if-up which is broken IMO in Raspbian Jessie
2) Run the aforementioned hook by a change to systemd configuration which, in Jessie is the mechanism in use, despite the presence of an old-style init.d script
so... what to do:
My script is /etc/dhcp/dhclient-enter-hooks.d/advertise
I cause dhcpcd to run the hooks by adding the "--script" option to the dhcpcd command run by systemd as found by...
$ pkg-config systemd --variable=systemdsystemunitdir
/lib/systemd/system
vi /lib/systemd/system/dhcpcd.service
[Service]
ExecStart - add "--script /sbin/dhclient-script" to the end of the command
$ systemctl daemon-reload
and...voila!
