StartX issue
Posted: Sun Dec 20, 2015 2:39 am
Hello! It's my first post and I look forward to many more
I'm relatively new to both python and linux. I've been trying to remote desktop into my raspberry pi, as to free up some space in my HDMI splitter. Startx has seemed like the simplest way to achieve this, however I'm having one issue that I can't seem to figure out. Below are is all I see:
Right now I am using kitty (nearly the exact same as putty) to ssh into it via: ssh -X pi@<iphere>
After there I type startx and get the errors listed above.
The only thing I've tried doing is going into
[XDMCPServer]
enabled = true | was #'d and false. Tried doing this and some said it would fix, but I noticed no changes.
Any ideas?
startx
X.Org X Server 1.12.4
Release Date: 2012-08-27
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.2.0-2-mx5 armv7l Debian
Current Operating System: Linux jacobpi1 3.18.7-v7+ #755 SMP PREEMPT Thu Feb 12 17:20:48 GMT 2015 armv7l
Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1552 bcm2708_fb.fbheight=868 bcm2709.boardrev=0xa01041 bcm2709.serial=0x5745ab86 smsc95xx.macaddr=B8:27:EB:45:AB:86 bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p6 rootfstype=ext4 elevator=deadline rootwait
Build Date: 11 February 2015 09:31:17PM
xorg-server 2:1.12.4-6+deb7u6 (Julien Cristau <jcristau@debian.org>)
Current version of pixman: 0.33.1
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.1.log", Time: Sun Dec 20 02:18:44 2015
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
FATAL: Module g2d_23 not found.
^Cxinit: connection to X server lost
waiting for X server to shut down Server terminated successfully (0). Closing log file.
xinit: unexpected signal 2
[XDMCPServer]
Any ideas?
