fraschizzato
SNMPD issue: pcilib: Cannot open /proc/bus/pci
Thu Dec 17, 2015 9:15 am
I've tried to install SNMPD using apt but during installation and on service start/restart I receive always that error: "pcilib: Cannot open /proc/bus/pci". The daemon is not running (googling I've found that someone reported the service runs even the error appears). Following the two answers at http://stackoverflow.com/questions/9470 ... oc-bus-pci I've tried to compile (with modification and/or both patch) net-snmp-5.7.1 - 5.7.2 and 5.7.3 but without success: the error is gone but the service is still not running, even if started manually (On service start I did not receive any response). Here the steps I've made (maybe there's something wrong):
unzip net-snmp source
./configure
patch < "patch.file"
make
make install
sudo /etc/init.d/snmpd restart -or- sudo service snmpd restart
(both without response or error)
and using
ps -A | grep snmpd -or- sudo service snmpd status
i did not receive any response:
[email protected] ~ $ sudo service snmpd restart
Hope someone can help to get it work
Re: SNMPD issue: pcilib: Cannot open /proc/bus/pci
Thu Dec 17, 2015 11:12 am
There's no such thing as a PCI bus on a raspberry (that's an Intel X86_64 thing). So you're going to need to find a configuration for snmpd that works for an ARM processor.
It's probably better to install a ready built daemon rather than trying to configure and build your own.
njohnsn
Sun Jun 05, 2016 11:07 pm
If you specify the IPv4 address of the Pi's interface in the following line in
/etc/snmp/snmpd.conf
, then stock SNMPD will start:
For example:
agentAddress udp:10.0.1.4:161,udp6:[::1]:161
My guess is that without an address SNMPD tries to find all possible network interfaces, including PCI ones.
ThomasDr
Sat May 18, 2019 3:49 pm
it looks like the PCI error is normal, the answer helped me.
regards
Thomas Dr
