DOA Zero
Posted: Mon Dec 07, 2015 7:33 pm
by m0nde
My daughter and I bought the magazine with free PiZero. We already have other Pi, so we expected no problems. We ordered the header pins and adapters from the swag store. Tonight we put in a mini sd from another working Pi, powered up. Neither PiZero has sign of life. No power LED.
Help would be appreciated.
Nigel & Colette
Re: DOA Zero
Posted: Mon Dec 07, 2015 7:36 pm
by hansotten
On the other Pi do a sudo apt-get update and upgrade, then insert in the zero.
Re: DOA Zero
Posted: Mon Dec 07, 2015 7:49 pm
by fruitoftheloom
m0nde wrote:My daughter and I bought the magazine with free PiZero. We already have other Pi, so we expected no problems. We ordered the header pins and adapters from the swag store. Tonight we put in a mini sd from another working Pi, powered up. Neither PiZero has sign of life. No power LED.
Nigel & Colette
What Operating System was on the SD Card ??
Re: DOA Zero
Posted: Mon Dec 07, 2015 7:53 pm
by m0nde
hansotten wrote:On the other Pi do a sudo apt-get update and upgrade, then insert in the zero.
Thank you for fast reply Hans.
Performed update and upgrade on old Pi. Went OK
Two PiZero still dead no LED, no HDMI out, nothing.
Nigel & Colette
Re: DOA Zero
Posted: Mon Dec 07, 2015 7:55 pm
by m0nde
Nigel & Colette
Raspian I think it is what we normally use.
Nigel & Colette
Re: DOA Zero
Posted: Mon Dec 07, 2015 8:04 pm
by drgeoff
Download the latest Raspbian, put it on the card and prepare to be pleasantly surprised.
Re: DOA Zero
by fruitoftheloom
Nigel & Colette
Nigel & Colette
Yes but Raspbian Wheezy or Jessie ?
sudo apt-get update
sudo apt-get dist-upgrade
sudo reboot
Re: DOA Zero
Posted: Mon Dec 07, 2015 8:06 pm
by m0nde
I have not heard of Jessie so probably it was Wheezy
Nigel & Colette
Re: DOA Zero
Posted: Mon Dec 07, 2015 8:08 pm
by fruitoftheloom
m0nde wrote:I have not heard of Jessie so probably it was Wheezy
Nigel & Colette
When you ran apt-get update it states what repository it is accessing :?
But IF it is Wheezy apart from what I listed above also run:
sudo rpi-update
sudo reboot
Re: DOA Zero
Posted: Mon Dec 07, 2015 8:13 pm
by m0nde
Thanks Fruitoftheloom. My eyesight not good enough to read this on daughters screen. I have to read resistor colour codes now with eye glass!. We are making a fresh Raspbian Jessie mini sd card on a spare. Will report progress. Down load is s l o w.....
Nigel & Colette
Re: DOA Zero Thank You
Posted: Mon Dec 07, 2015 9:09 pm
by m0nde
Thank you for your replies everyone Colette has her PiZero running and I will now presumably get mine running too.
Best wishes
Nigel & Colette
8-) :D
