sharkbait11
IMAPclient wont install properly
Mon Nov 30, 2015 3:56 am
Hey guys!
I got my Pi a few weeks ago and I've been tinkering with it. I want to setup my pi to notify my when i get an email with LED's. So I've been following an online guide.
Well the issue is when I try to run -
sudo apt-get install imapclient
I get the following error -
This is my hold up at the moment. Anyone ran into this before?
Downloading/unpacking imapclient
  Running setup.py egg_info for package imapclient
    mock requires setuptools>=17.1. Aborting installation
      File "<string>", line 14, in <module>
      File "/home/pi/build/imapclient/setup.py", line 105, in <module>
        cmdclass={'test': TestDiscoverCommand})
      File "/usr/lib/python2.7/distutils/core.py", line 112, in setup
        _setup_distribution = dist = klass(attrs)
      File "/usr/lib/python2.7/dist-packages/setuptools/dist.py", line 221, in __init__
        self.fetch_build_eggs(attrs.pop('setup_requires'))
      File "/usr/lib/python2.7/dist-packages/setuptools/dist.py", line 245, in fetch_build_eggs
        parse_requirements(requires), installer=self.fetch_build_egg
      File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 576, in resolve
        dist = best[req.key] = env.best_match(req, self, installer)
      File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 821, in best_match
        return self.obtain(req, installer) # try and download/install
      File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 833, in obtain
        return installer(requirement)
      File "/usr/lib/python2.7/dist-packages/setuptools/dist.py", line 294, in fetch_build_egg
        return cmd.easy_install(req)
      File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 608, in easy_install
        return self.install_item(spec, dist.location, tmpdir, deps)
      File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 638, in install_item
        dists = self.install_eggs(spec, download, tmpdir)
      File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 828, in install_eggs
        return self.build_and_install(setup_script, setup_base)
      File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 1105, in build_and_install
        self.run_setup(setup_script, setup_base, args)
      File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 1096, in run_setup
        raise DistutilsError("Setup script exited with %s" % (v.args[0],))
    distutils.errors.DistutilsError: Setup script exited with 1
    Complete output from command python setup.py egg_info:
sharkbait11
Re: IMAPclient wont install properly
Tue Dec 01, 2015 3:53 am
For anyone with a similar issue I went to this link and verified all of my libraries.
Looks like I was missing a few-
https://jeffskinnerbox.wordpress.com/li ... pberry-pi/
Aydan
Tue Dec 01, 2015 9:50 am
sharkbait11 wrote:For anyone with a similar issue I went to this link and verified all of my libraries.
That means the package has incomplete dependencies.
This should be fixed by the package maintainer.
KnightOfPi
Wed Dec 16, 2015 11:59 am
i did have the same problem- imapclient installation didn't work on a pre-Jessie Raspbian.
Here is how i fixed it:
sudo pip install --upgrade setuptools
wget https://pypi.python.org/packages/source/m/mock/mock-1.3.0.tar.gz
tar xf mock-1.3.0
cd mock-1.3.0
sudo python setup.py install
sudo apt-get install libffi-dev python-pip
sudo pip install imapclient
Have fun!
Check out www.knight-of-pi.org for many beginner-friendly tutorials!
depauw
Mon Mar 28, 2016 6:41 pm
i'v tried the solution of sharkbait11, but i've got this error
tar: mock-1.3.0: Function open() failed: file or map does not exist
tar: Error is not recoverable: exiting now
Any suggestions?
kind regards,
Christophe
