norpi
My 3 rpi's are not booting anymore
Sun Nov 29, 2015 1:36 pm
Hi
I have 3 Rpi 2+ all with a dedicated sdcard. After somths of other projects I have started looking into using the rpis again. However I cannot get them to boot.
I have tried new imaged of raspbian, noobs and musicbox on the cards which I use SD formatter on first and then copy the image on the card using win2Diskimager.
I have tried a dedicated 5V 2A supply and also a USB port from the computer, both used to work earlier
I only connect the hdmi and the power cable, no extra addons. Card clicks in the correct way.
Symptoms are:
*black screen. I have 2 LCD monitors with different hdmi cables which used to work but doesnt work now.
*Red and green light comes on but stays on. The green does not start blinking.
Before pointing out faulty cables and cards, please note that I have tried at least two different instances of all the components.
Any hints and help is much appreciated.
Regards, Bjørnar
