Dia Segmentation Fault
Posted: Wed Nov 25, 2015 9:19 pm
by rlsj
Running RPI2 32GB, 1920x1080 display, Raspbian:
Installed Dia diagram and flowcharting program, which suffers a segmentation fault immediately upon invocation by command line, simply stops if by menu. Would appreciate any advice.
--rlsj
Re: Dia Segmentation Fault
Posted: Wed Nov 25, 2015 10:51 pm
by buja
No solution, I installed Dia and see the same thing (RPi2, Raspbian Jessie).
From the GUI the program starts, showing the small Dia title window indicating it's loading the program. As soon as the main window is opened the program exits.
Starting from the command line the title window shows too, but then the program exits with this error:
The program 'dia-normal' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadMatch (invalid parameter attributes)'.
  (Details: serial 3823 error_code 8 request_code 70 minor_code 0)
  (Note to programmers: normally, X errors are reported asynchronously;
   that is, you will receive the error a while after causing it.
   To debug your program, run it with the --sync command line
   option to change this behavior. You can then get a meaningful
   backtrace from your debugger if you break on the gdk_x_error() function.)
Posted: Sat Nov 28, 2015 9:36 am
by buja
I tried to start Dia on Raspbian Wheezy with the same error result:
(dia-normal:7235): GLib-GObject-WARNING **: Attempt to add property GtkSettings::gtk-label-select-on-focus after class was initialised
sys:1: Warning: Attempt to add property GtkSettings::gtk-button-images after class was initialised
sys:1: Warning: Attempt to add property GtkSettings::gtk-scrolled-window-placement after class was initialised
sys:1: Warning: Attempt to add property GtkSettings::gtk-can-change-accels after class was initialised
sys:1: Warning: Attempt to add property GtkSettings::gtk-menu-popup-delay after class was initialised
sys:1: Warning: Attempt to add property GtkSettings::gtk-menu-popdown-delay after class was initialised
sys:1: Warning: Attempt to add property GtkSettings::gtk-entry-select-on-focus after class was initialised
sys:1: Warning: Attempt to add property GtkSettings::gtk-entry-password-hint-timeout after class was initialised
sys:1: Warning: Attempt to add property GtkSettings::gtk-menu-bar-popup-delay after class was initialised
sys:1: Warning: Attempt to add property GtkSettings::gtk-menu-images after class was initialised
sys:1: Warning: attempting to add an interface (DiaInteractiveRendererInterface) to class (DiaGdkRenderer) after class_init
** (dia-normal:7235): CRITICAL **: dia_renderer_set_size: assertion 'irenderer != NULL' failed
Segmentation fault
When I tried on a Pi with Ubuntu Mate 15.10 Dia worked well.
Dia also runs well on a Dell laptop with Debian Jessie (Dia version 0.97.3).
Dia is version 0.97.2 in all cases.
Correction:
  • Wheezy has Dia version 0.97.2, aborts
  • Jessie has Dia version 0.97.3, aborts
  • Ubuntu 15.10 has Dia version 0.97.3, runs well
The conclusion so far is that the problem is somewhere in Raspbian, Wheezy as well as Jessie. What would be the best place to submit a bug report?
Posted: Sat Nov 28, 2015 5:05 pm
by buja
I just submitted a bug report at the Raspbian site.
Posted: Sat Oct 29, 2016 9:50 am
by buja
I just upgraded to the Pixel desktop and now Dia works like it should.
