Sat Nov 21, 2015 10:05 am
hello everyone that answered my post, I thank you, but...
I have boot my rasp in command line, changed CONF_SWAPSIZE=100 to 120, and tried to run again
sudo apt-get update
sudo apt-get upgrade
and I got hanging again like this:
pi@raspberrypi ~ $ sudo dpkg --configure -a
pi@raspberrypi ~ $ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages have been kept back:
raspberrypi-ui-mods
The following packages will be upgraded:
bluej dhcpcd5 epiphany-browser epiphany-browser-data fonts-opensymbol gir1.2-gdkpixbuf-2.0 gir1.2-gtk-3.0 gstreamer1.0-omx
krb5-locales libfreetype6 libfreetype6-dev libgdk-pixbuf2.0-0 libgdk-pixbuf2.0-common libgtk-3-0 libgtk-3-bin libgtk-3-common
libjavascriptcoregtk-3.0-0 libk5crypto3 libpixman-1-0 libpng12-0 libpng12-dev libreoffice libreoffice-avmedia-backend-gstreamer
libreoffice-base libreoffice-base-core libreoffice-base-drivers libreoffice-calc libreoffice-common libreoffice-core libreoffice-draw
libreoffice-gtk libreoffice-impress libreoffice-java-common libreoffice-math libreoffice-report-builder-bin libreoffice-style-galaxy
libreoffice-writer libsasl2-2 libsasl2-modules libsasl2-modules-db libvdpau1 libwebkitgtk-3.0-0 libwebkitgtk-3.0-common ntp nuscratch
python3-pgzero python3-uno raspberrypi-net-mods raspi-config rc-gui uno-libs3 unzip ure wpasupplicant
54 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Need to get 0 B/112 MB of archives.
After this operation, 2414 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_CTYPE = "UTF-8",
LANG = "en_GB.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_GB.UTF-8").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
Extracting templates from packages: 100%
(Reading database ... 117463 files and directories currently installed.)
Preparing to unpack .../libk5crypto3_1.12.1+dfsg-19+deb8u1_armhf.deb ...
Unpacking libk5crypto3:armhf (1.12.1+dfsg-19+deb8u1) over (1.12.1+dfsg-19) ...
Preparing to unpack .../libsasl2-modules-db_2.1.26.dfsg1-13+deb8u1_armhf.deb ...
Unpacking libsasl2-modules-db:armhf (2.1.26.dfsg1-13+deb8u1) over (2.1.26.dfsg1-13) ...
Preparing to unpack .../libsasl2-2_2.1.26.dfsg1-13+deb8u1_armhf.deb ...
Unpacking libsasl2-2:armhf (2.1.26.dfsg1-13+deb8u1) over (2.1.26.dfsg1-13) ...
Preparing to unpack .../libpng12-dev_1.2.50-2+deb8u1_armhf.deb ...
Unpacking libpng12-dev:armhf (1.2.50-2+deb8u1) over (1.2.50-2) ...
Preparing to unpack .../libpng12-0_1.2.50-2+deb8u1_armhf.deb ...
Unpacking libpng12-0:armhf (1.2.50-2+deb8u1) over (1.2.50-2) ...
Preparing to unpack .../libfreetype6-dev_2.6-2rpi1rpi1g_armhf.deb ...
Unpacking libfreetype6-dev (2.6-2rpi1rpi1g) over (2.5.2-4rpi1rpi1g) ...
packet_write_wait: Connection to 192.168.1.109: Broken pipe
At this moment my top reports freezes with:
top - 09:46:30 up 9 min, 2 users, load average: 1.17, 0.65, 0.33
Tasks: 94 total, 1 running, 93 sleeping, 0 stopped, 0 zombie
%Cpu(s): 0.2 us, 1.7 sy, 0.0 ni, 73.1 id, 24.9 wa, 0.0 hi, 0.0 si, 0.0 st
KiB Mem: 948120 total, 510540 used, 437580 free, 63672 buffers
KiB Swap: 122876 total, 0 used, 122876 free. 370656 cached Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
1199 root 20 0 33300 30116 26184 S 6.9 3.2 0:04.79 apt-get
1055 root 20 0 5092 2496 2140 R 2.0 0.3 0:02.18 top
1276 root 20 0 22096 19524 2232 D 1.0 2.1 0:01.20 dpkg
1 root 20 0 5456 3952 2736 S 0.0 0.4 0:04.76 systemd
2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd
3 root 20 0 0 0 0 S 0.0 0.0 0:00.02 ksoftirqd/0 ...
and I have to unplug my rasp from the power supply to restart.
This is a fresh installation of Jessie.
I will appreciate any new ideas to solve this issue!
