Hockmiester
New Pi Invalid MIT-COOKIE-1
Fri Jul 27, 2012 9:09 am
Hi
I purchased a Pi for my daughter with a pre purchased OS on a SD. We hooked it all up and started the power. After entering the PW and startx the screen when blank for a few minutes.
Then I got a page of Invalid MIT-MAGIC-COOKIE-1 Key.. then 'giving up' followed by
server error and error in locking autherity file /home/pi/.Xauthority
This is a new Pi being booted for the first time.
Cheers
Mike
jayer89
Re: New Pi Invalid MIT-COOKIE-1
Fri Jul 27, 2012 7:24 pm
try reflashing your SD card and install the OS again then try again.
hibol
Fri Jul 27, 2012 7:30 pm
This is exactly the problem I have too.
Sorry for opening meanwhile another topic about this issue... :oops:
Just let me now if reflashing your SD card solved the problem ! ;)
PeterO
Fri Jul 27, 2012 7:44 pm
MIT-COOKIEs are stored in a file called .Xauthority in your home directory.
Try deleting it with rm ~/.Xauthority then try startx again.
PeterO
ramsey
Fri Mar 20, 2015 8:11 pm
Well pi golly that's good.
I observed that got this error message ... sometimes. Turns out 'sudo leafpad ...' worked fine when I had all the keyboard/mouse/monitor connected and used the native session, but FAILED using VNC.
So I did as recommended and deleted .Xauthority from VNC ... and BEHOLD! I could do 'sudo leafpad' just fine. Back to the native session. All to once it was failing. Restarted X and I could do it again.
I note that deleting .Xauthority from the VNC session also made it go away in the native session (same user, pi). Running "sudo leafpad" in VNC recreated .Xauthority, but it was not visible in the native session until I restarted X.
PeterO
Fri Mar 20, 2015 8:14 pm
WOW !!!! Incomprehensible reply to three year old dead thread.
PeterO
