Supernova99
OpenVPN fails to start on bootup
Thu Nov 12, 2015 4:13 pm
Apologies if this has been asked before.
I am new to the Rpi and linux, but very capable of understanding technical issues and troubleshooting them.
I decided that I needed to make my own VPN server, as I travel extensively and I wanted something more secure when away, especially using open public WiFi hotspots.
So I came across a great How-to build a VPN server using a Rpi and OpenVPN
http://www.bbc.co.uk/news/technology-33548728
I installed Raspbian (4.1.12+) and updated and upgraded to the latest.
I followed the How-to exactly, but I did run into a few issues, which I patiently resolved by using our friend Google.
All was working as expected, except once I rebooted, the iptables were never restored.
The main issues were around saving iptables, which I managed to resolve using iptables-persistent.
http://blog.mxard.com/persistent-iptabl ... i-raspbian
However during the install of this, the post advised that I upgrade my Pi firmware and distro.
Once all was installed I noticed that on bootup I was getting a [FAILED] Failed to start OpenVPN connection to server.
See 'systemctl status [email protected]' for details.
So I ran the command [systemctl status [email protected]] as suggested by the failure, and indeed the OpenVPN service (which had been running previously before) was stopped.
I then tried to start it using the command
[service openvpn start]
I checked the status of the service and it is now running.
I rebooted the Rpi but I could still see that on startup it was still failing to start.
Another Google took me to creating a startup script -
/etc/rc.local
I added the command
[sudo service openvpn start &]
Now when I bootup I can still see the service fail, but then a few lines below, I can now see that it has started.
All is good the openVPN service, survives a reboot.
My question as a newbie is this -
Is this the correct fix?
The service should autostart from it's own script -
/etc/init.d/openvpn
It is somehow not starting by itself during bootup.
Should I add the openvpn script into the rc.local?
I have had a look at the script and it is quite complicated, and a bit above my head to understand all the parameters and switches.
I would just like to understand why it is not loading at startup, and perhaps fix it correctly rather than use a workaround.
openvpn.zip
openvpn script file
(2.84 KiB) Downloaded 47 times
Something changed in the software/firmware upgrade, that now prevents the openvpn service from starting on bootup.
Any help greatly appreciated.
I hope someone out there can shed some light.
tieke
Re: OpenVPN fails to start on bootup
Wed Feb 03, 2016 10:08 pm
This reply is probably a bit late for you, but I had the same issue and fixed it by commenting out the initial line in the server.conf file - ie it now says # local 192.168.0.136.
Hope that helps.
