I've had my Rasberry Pi B+ for some time now but haven't installed anything on it yet. Yesterday I thought I would give it a try since I need it for a Linux class. However it seems there is a bug that has been around since at least sometime 2013. Why it isn't fixed and exactly what causes the problem is, since I'm no Linux user a bit hard to understand. From what I have read the file cmdline.txt points to the wrong place.
The problem is known by the error message: kernel panic not syncing vfs unable to mount root fs on unknown-block(179,6)
I've tried:
Installing noobs
Installing noobs that is modified in the file os/Rasbian/boot.tar -->.\cmdline.txt The mmcblk0p2 is now mmcblk0p6
Installing rabsian via win32 diskimager
Installing rabsian via win32 diskimager with the file cmdline.txt modified.
Installing ubunto lite via win32 diskimager
Before each installation the SD-card has been formated with the SDFormatter tool.
It can't be meant to be this hard to get the Rasberry to work. And I can't see how this still is a problem with no good solution guide yet. It could be the SD-card, but since I don't own more then one that is the last thing I would like to try since I'll have to buy another one then. Could anyone explain what the problem is and how i might get my Rasberry to boot properly?
Thanks in advice!
