nikohal2015
rc.local error
Thu Nov 05, 2015 9:56 pm
I use rasbian. And the problem is ups not start up or when power going down, it's shutdown. Accu is full. And when it's boot it give error rc.local file. Error: "Failed to start /etc/init.d/rc.local Compatibility.
See 'systemctl status rc-local.service' for details.
So I try to fix it with this way: https://bbs.archlinux.org/viewtopic.php?id=147790
But no help.
Here is rc.local file content:
# Print the IP address
_IP=$(hostname -I) || true
if [ "$_IP" ]; then
printf "My IP address is %s\n" "$_IP"
fi
# Run UPS Pico FSSD script and load the included emulated RTC
sudo python /home/pi/picofssd.py &
echo ds1307 0x68 > /sys/class/i2c-adapter/i2c-1/new_device
( sleep 4; hwclock -s ) &
exit 0
gordon77
Re: rc.local error
Thu Nov 05, 2015 10:21 pm
I think the problem is with Jessie you can't set the rtc in rc.local
See viewtopic.php?f=66&t=85683&p=838067#p838067
Re: rc.local error
Fri Nov 06, 2015 6:45 am
You don't need sudo in rc.local as it is run by the root user anyway.
fruit-uk
Re: rc.local error
Fri Nov 06, 2015 7:45 am
gordon77 wrote:I think the problem is with Jessie you can't set the rtc in rc.local
There is a more concise one at viewtopic.php?f=66&t=125003
There may be other RTC (at least) issues if upgrading.
Many wheezy RTC methods involved editing /etc/init.d/hwclock.sh and /etc/default/hwclock in various ways
Upgrades will not usually overwrite user-modified files (a dialogue is often presented when this occurs) so it is worth checking wheher you still have those wheezy modified files in those positions
Edit:
I have no idea how dist-upgrade copes with this, I always do a fresh install, keeping a copy of my old stuff of course, when doing a major upgrade
