divahar300
Ethernet connection not working
Sat Oct 31, 2015 5:09 pm
hi all,
Recently i brought Rasp pi 2 and tried connecting headless. when i pinging raspi 2 with my pc (ping raspberrypi.mshome.net), I get request time out.
However i connected the pi to a monitor and found the ip address of pi by ifconfig. when i manually ping by entering the ip address, i get response.
Also, though I've enabled the network sharing in my wi fi settings, I am not able to use internet in my pi via my pc
help me to find a solution
lmarmisa
Re: Ethernet connection not working
Sat Oct 31, 2015 8:07 pm
Take a look to this link:
http://packetlife.net/blog/2008/sep/24/ ... explained/
Something is wrong related to DHCP there. If the IP address of your RPi is 169.254.1.104, this is not a good signal.
If the DHCP protocolo works correctly, the IP address will be something like 192.169.x.y.
I recommend to post here the outputs of these commands:
1) RPi
ifconfig
route -n
2) PC
ipconfig
route print -4
fiazmr
Fri Apr 19, 2019 5:29 am
Browsing through some articles I came to know that my shared ip had changed for the pi. When I do >ping raspberrypi.mshome.net on command prompt its showing request timed out. As I was working out on a small project and what this sorted out immediately I went to the network options under control panel, selected my wifi connection disabled allow sharing under properties. Enabled it again and connected the pi and got a new ip address. Then I was able to successfully connect to pi using Putty. I know this could not be a long time solution.
