Onira
No wireless connection icon, only wired (disconnected)
Fri Oct 23, 2015 1:15 pm
Hello
RPi2 on default xsession shows connection icon
but it is always an icon of wired connection
but there is NO icon for wireless connection
Is there a way to display the proper icon?
Cogito ergo sum
Re: No wireless connection icon, only wired (disconnected)
Fri Oct 23, 2015 2:51 pm
Onira wrote:Hello
The Internet Connection Icon is for both Ethernet & Wireless
https://www.raspberrypi.org/blog/anothe ... ace-update
adieu
My other Computer is an Asus CS10 ChromeBit running Chrome Operating System.
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Buster.
Raspberry Pi Model 2B v1.1
Onira
Sun Oct 25, 2015 7:21 am
But I don't have wifi icon, when I use wifi there is always an icon of wired connection and it's showing disconnected (ethernet not plugged in).
Cogito ergo sum
MrEngman
Sun Oct 25, 2015 7:38 am
Onira wrote:But I don't have wifi icon, when I use wifi there is always an icon of wired connection and it's showing disconnected (ethernet not plugged in).
The network icon is used by both wired and wifi networks. If you do not have a wifi connection it will show the wired network icon. When you make a wifi connection it will change to the wifi icon.
If you select the icon with your mouse and left click the icon you should see a list of wifi networks. Then select the wifi network you want to connect to.
MrEngman
Onira
Sun Oct 25, 2015 5:06 pm
that's what I'm trying to tell
I don't get change to wifi icon and there is always wired, disconnected icon there when using wifi.
Cogito ergo sum
MrEngman
Sun Oct 25, 2015 6:08 pm
Onira wrote:that's what I'm trying to tell
Sorry, may be I did not understand what you said. Are you saying your wifi on the Pi is working so you can access your network and the internet from your Pi but the icon is still showing the two computers and not the wifi icon? Like this
If it is then I don't know why your icon has not changed to the wifi icon.
MrEngman
Onira
Mon Oct 26, 2015 2:31 pm
thets exactly what I was trying to say all the time :P
Cogito ergo sum
