RaTTuS wrote:that will cause the RPi to stay in reset mode so yes it will not work after being soldered
No, he said there's no short between the terminals.
@kalle67:
did you take care while soldering that there was no ESD? You might have killed the run pin.
What you can check is if one of the pins is at 3.3V (there's a pullup on one pin, the other one is GND)
Regards
Aydan
