DaHai8
stunnel under Jessie issue
Wed Sep 30, 2015 2:58 pm
I have two seemingly identically set up RPi's. One is Wheezy and the other is Jessie.
Both have OpenVPN Server and stunnel4 installed and configured - identically.
Wheezy works great. Connect with stunnel client on my Android with SSLDroid and OpenVPN for Android and data flows like it should.
Jessie does not. If I connect straight with OpenVPN (no stunnel), data flows great. Try to go through stunnel, and OpenVPN connects, but no data flows (no web pages, email, internet)
Here's my stunnel.conf:
sslVersion = all
options = NO_SSLv2
cert = /etc/stunnel/server.pem
pid = /var/run/stunnel.pid
output = /var/log/stunnel
socket = l:TCP_NODELAY=1
[openvpn]
client = no
accept = 443
connect = 10.254.22.117:1194
And here's the top of my OpenVPN Server.conf:
local 10.254.22.117
dev tun
proto tcp
port 1194
ca /etc/openvpn/easy-rsa/keys/ca.crt
Hope someone can tell me where I'm going wrong, or where to look for more clues!
Thanks!
DaHai8
Re: stunnel under Jessie issue
Thu Oct 01, 2015 3:50 am
Well, the problem wasn't with Jessie or anything on the server. I had such a hard time trying to get OpenVPN to autostart on boot in Jessie that I thought something was different with stunnel as well.
Turned out, the problem was on the client side. I forgot to add this route command to the client config to keep it from rerouting packets meant for the server:
route xxx.xxx.xxx.xxx 255.255.255.255 net_gateway
Where xxx.xxx.xxx.xxx is the ip address of the OpenVPN Server/stunnel Server.
What a difference a good night's sleep makes :D
Case closed.
