BENSALVAGE
GPIO cleanup
Sat Sep 26, 2015 1:56 pm
Hi guys I'm looking for some assistance, I keep having warning messages saying pins already in use, however my programme is failing because of this and not allowing me to do a clean up is there another method to cleanup perhaps from the command line to reset all the pins? Also what would be the best way to cleanup in future if a programme fails of crashes before it can be cleaned up?
Hope this makes sense guys
Kind regards
joan
Re: GPIO cleanup
Sat Sep 26, 2015 2:12 pm
A warning should not make your program fail.
Why do you think it is failing?
BENSALVAGE
Re: GPIO cleanup
Sat Sep 26, 2015 2:26 pm
Well it won't allow me to use the GPIO pins
RogerW
Re: GPIO cleanup
Sat Sep 26, 2015 2:31 pm
BENSALVAGE wrote:Well it won't allow me to use the GPIO pins
Are you sure you are running with sudo priviledge?
joan
Re: GPIO cleanup
Sat Sep 26, 2015 2:34 pm
So you say.
To make progress you need to offer some evidence.
A listing of the script together with a cut&paste of the messages you get when running the script would be useful. As would a description of what you expect to happen against what actually happens.
