chrisrios88
VCHIQ Error on Rasberry Pi 2
Thu Sep 17, 2015 10:17 pm
I had an existing image from my Raspberry Pi B that I upgraded and got running on the Raspberry Pi 2, so it boots fine without a problem (I primarily use it to run Omxplayer)
When I try to run omxplayer I get an error:
* failed to open vchiq instance
A grep of dmesg shows:
dmesg | grep vchi
[ 1.713870] vchiq: vchiq_init_state: slot_zero = 0x8ec80000, is_master = 0
[ 1.723651] bcm2835_vchiq 3f00b840.vchiq: failed to set channelbase
[ 1.732203] vchiq: could not load vchiq
[ 1.737952] bcm2835_vchiq: probe of 3f00b840.vchiq failed with error -1908864768
uname -a:
Linux FL-SLCC1-PI 4.1.7-v7+ #815 SMP PREEMPT Thu Sep 17 18:34:33 BST 2015 armv7l GNU/Linux
Kind of at a loss here because I can't find anything on the errors I'm getting, everything I've found is related to /dev/vchiq but my problem is that doesn't exist since that's created when the VCHIQ module loads properly (which it doesn't)
Any help would be appreciated. Thank you!
Chris
stas2
Re: VCHIQ Error on Rasberry Pi 2
Sat Sep 19, 2015 8:04 pm
Hi, I was trying to run latest kernel (from 4.2.y branch) and had a similar error but different error code.
Resolved by updating firmware to the latest version from https://github.com/raspberrypi/firmware .
Hope this helps
chrisrios88
Tue Sep 22, 2015 1:48 pm
Thanks! Is there an easy way to configure rpi-update to use the 4.2.y fork instead of 4.1?
Tue Sep 22, 2015 8:30 pm
chrisrios88 wrote:Thanks! Is there an easy way to configure rpi-update to use the 4.2.y fork instead of 4.1?
Not until the RPF folks switch over from 4.1.x to 4.2.x.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
Since 2012: 1B*5, 2B*2, B+, A+, Zero*2, 3B*3
Please post ALL technical questions on the forum. Do not send private messages.
jward
Wed Oct 07, 2015 9:30 pm
I have essentially the same problem except for the returned error code. I updated the firmware but that didn't fix the problem. Is that all you had to do to fix yours?
I posted the specifics of my problem here:
Camera no longer works, vchiq seems to be the problem
viewtopic.php?f=63&t=122571
stas2
Thu Oct 08, 2015 1:03 pm
Hello jward,
For me yes, all I had to do was updating the firmware.
The raspberry pi official touch screen display did not work with kernel 3.18 I was running and I updated to the latest kernel 4.x. First I could not get any graphical applications to work. There were similar messages in the log as in the first post of this thread, but different error code. There was no /dev/vchiq. Once I had updated the firmware the error had gone and everything was working OK.
Who is online
Users browsing this forum: Gustave_Coste, rpiMike, Tinko and 47 guests
