platitude
MFRC522 + Raspberry Pi B+
Fri Sep 11, 2015 8:05 pm
Hello. I'm trying to connect a RFID module to my Raspberry Pi. I'm trying to use rpi-rc522 (https://code.google.com/p/rpi-rc522/) but i can only see ("Debug mode" message when running "sudo ./rc522_reader -d"). Connection looks like:
sda - 24
sck - 23
mosi - 19
miso - 21
gnd - 20
rst - 22
3.3v - 17
File /boot/config.txt:
# For more options and information see
# http://www.raspberrypi.org/documentation/configuration/config-txt.md
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=-16
#overscan_right=-16
#overscan_top=-16
#overscan_bottom=-16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
dtparam=i2c_arm=on
# dtparam=i2c=on
#dtparam=i2s=on
dtparam=spi=on
#dtoverlay=spi-bcm2835
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# NOOBS Auto-generated Settings:
config_hdmi_boost=4
overscan_left=1
overscan_right=2
overscan_top=1
overscan_bottom=2
disable_overscan=1
start_x=0
gpu_mem=128
core_freq=250
sdram_freq=400
over_voltage=0
lsmod:
rtc_ds1307             10383  0
cfg80211              501663  0
rfkill                 22491  1 cfg80211
i2c_dev                 6737  0
snd_bcm2835            22339  3
snd_pcm                92573  1 snd_bcm2835
snd_seq                62040  0
snd_seq_device          5130  1 snd_seq
snd_timer              23456  2 snd_pcm,snd_seq
snd                    68161  11 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device
8192cu                569532  0
i2c_bcm2708             6252  0
spi_bcm2835             7796  0
uio_pdrv_genirq         3690  0
uio                    10009  1 uio_pdrv_genirq
platitude
Re: MFRC522 + Raspberry Pi B+
Sun Sep 13, 2015 1:00 pm
UP. Anyone?
with ice cream
Sat Sep 19, 2015 11:45 pm
Not helpful, but I am in the same situation. I rewired everything twice, tried the python code that is floating around - no dice.
with ice cream
Sun Sep 20, 2015 12:06 am
A few minutes later: solved for me. The key was this comment. The library works (best/only) with a Pi 2 with version 1.40.
Here's what I did (I keep my sources in ~/src):
cd ~/src/bcm2835-1.36
sudo make uninstall
cd  ~/src
wget http://www.airspayce.com/mikem/bcm2835/bcm2835-1.40.tar.gz
tar -zxf bcm2835-1.40.tar.gz
cd bcm2835-1.40/
./configure
sudo make install
cd ../rpi-rc522-read-only/
gcc config.c rfid.c rc522.c main.c -o rc522_reader -lbcm2835
cd rc522/
sudo cp RC522.conf /etc/
Good luck!
danjperron
Sun Sep 20, 2015 12:39 pm
but I can only see ("Debug mode" message when running "sudo ./rc522_reader -d")
Did you put your serial number and the command into /etc/RC522.conf ?
I just reply to a post showing exactly what you are missing
viewtopic.php?p=818250&sid=95628c938039 ... ff#p818250
Works fine with the B+ also.
