garga_mel
Ondemand governor never scales down when overclocking
Mon Sep 07, 2015 7:47 pm
Hi all,
I have tried to overclock my RPI2 running raspbian wheezy using the following settings in /boot/config.txt
arm_freq=1000
core_freq=400
sdram_freq=450
over_voltage=2
gpu_mem=64
initial_turbo=30
This seems to improve the overall speed. However my pi2 never seems to scale down to 600 Mhz even when idle. :(
This is the output of cpufreq-info
current CPU frequency is 1000 MHz.
cpufreq stats: 600 MHz:0.00%, 1000 MHz:100.00%
What am I missing ?
JimmyN
Re: Ondemand governor never scales down when overclocking
Tue Sep 08, 2015 12:37 pm
Using "initial_turbo=30" in config.txt just sets turbo for initial boot, in this case for 30 seconds or until cpufreq sets a frequency, whichever occurs first.
You need to change the threshold for the ondemand governor, which is located at
/sys/devices/system/cpu/cpufreq/ondemand/up_threshold
I usually set mine at "50", I think the default is somewhere around "90" IIRC, and I typically get something like this from "cpufreq-info"
  current CPU frequency is 700 MHz.
  cpufreq stats: 700 MHz:97.62%, 900 MHz:2.38%  (2081)
garga_mel
Tue Sep 08, 2015 5:28 pm
I had "95" as an up_threshold value :
cat /sys/devices/system/cpu/cpufreq/ondemand/up_threshold
95
I tried to change the value to "50" but it did not change anything :(
My CPU is stuck at 1000 Mhz instead of going back to 600 Mhz.
I'm am getting even more puzzeled here : I did not set arm_freq_min=600 and it appears that the default value is 700 mhz.
sudo vcgencmd get_config arm_freq_min
arm_freq_min=0
garga_mel
Tue Sep 08, 2015 7:16 pm
Thanks for the help I have made some progress and using a fresh raspbian installation that the issue starts when I install the cpufrequtils package.
If I manually set the cpufreq min it seems to work fine :
sudo cpufreq-set --min 800
cpufreq-info
cpufreq stats: 600 MHz:97.55%, 1000 MHz:2.45%  (8)
But I am still stuck at the 600 Mhz instead of 800 Mhz :(
Are the cpufreqd and cpufrequtils required for an overclock of the pi 2 ?
