Slow SSH login (not related to DNS or authentication)
Posted: Thu Sep 03, 2015 10:00 am
I have sshd on Arch Linux. When I connect, it hangs for about 30 seconds at the following message:
Reverse DNS lookups are disabled, GSSAPI is disabled, and the hang happens after authentication has completed successfully and before starting the shell, so it's probably not a shell problem either.
What else could be causing the hang?
Here's the full debug log:
The hang is also present when using scp etc.
debug1: Entering interactive session.
% ssh -vvv localhost
OpenSSH_6.8p1, OpenSSL 1.0.2c 12 Jun 2015
debug1: Reading configuration data /etc/ssh/ssh_config
debug2: ssh_connect: needpriv 0
debug1: Connecting to localhost [127.0.0.1] port 22.
debug1: Connection established.
debug1: identity file /home/human/.ssh/id_rsa type 1
debug1: key_load_public: No such file or directory
debug1: identity file /home/human/.ssh/id_rsa-cert type -1
debug1: identity file /home/human/.ssh/id_dsa type -1
debug1: identity file /home/human/.ssh/id_dsa-cert type -1
debug1: identity file /home/human/.ssh/id_ecdsa type -1
debug1: identity file /home/human/.ssh/id_ecdsa-cert type -1
debug1: identity file /home/human/.ssh/id_ed25519 type -1
debug1: identity file /home/human/.ssh/id_ed25519-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_6.8
debug1: Remote protocol version 2.0, remote software version OpenSSH_6.8
debug1: match: OpenSSH_6.8 pat OpenSSH* compat 0x04000000
debug2: fd 3 setting O_NONBLOCK
debug3: hostkeys_foreach: reading file "/home/human/.ssh/known_hosts"
debug3: record_hostkey: found key type ECDSA in file /home/human/.ssh/known_hosts:14
debug3: load_hostkeys: loaded 1 keys from localhost
debug3: order_hostkeyalgs: prefer hostkeyalgs: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: kex_parse_kexinit: curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1
debug2: kex_parse_kexinit: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-ed25519-cert-v01@openssh.com,ssh-rsa-cert-v01@openssh.com,ssh-dss-cert-v01@openssh.com,ssh-rsa-cert-v00@openssh.com,ssh-dss-cert-v00@openssh.com,ssh-ed25519,ssh-rsa,ssh-dss
debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com,chacha20-poly1305@openssh.com,arcfour256,arcfour128,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se
debug2: kex_parse_kexinit: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1,hmac-md5-etm@openssh.com,hmac-ripemd160-etm@openssh.com,hmac-sha1-96-etm@openssh.com,hmac-md5-96-etm@openssh.com,hmac-md5,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
debug2: kex_parse_kexinit: none,zlib@openssh.com,zlib
debug2: kex_parse_kexinit: first_kex_follows 0
debug2: kex_parse_kexinit: reserved 0
debug2: kex_parse_kexinit: ssh-rsa,ssh-dss,ecdsa-sha2-nistp256,ssh-ed25519
debug1: kex: server->client aes128-ctr umac-64-etm@openssh.com none
debug1: kex: client->server aes128-ctr umac-64-etm@openssh.com none
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ecdsa-sha2-nistp256 SHA256:MT39OUhxkKZhg6E3AhnZV1cushkuoVgSuYm4A1nMLYM
debug1: Host 'localhost' is known and matches the ECDSA host key.
debug1: Found key in /home/human/.ssh/known_hosts:14
debug2: set_newkeys: mode 1
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug2: set_newkeys: mode 0
debug1: SSH2_MSG_NEWKEYS received
debug1: Roaming not allowed by server
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug2: key: /home/human/.ssh/id_rsa (0xb75550b0),
debug2: key: /home/human/.ssh/id_dsa ((nil)),
debug2: key: /home/human/.ssh/id_ecdsa ((nil)),
debug2: key: /home/human/.ssh/id_ed25519 ((nil)),
debug1: Authentications that can continue: publickey,password
debug3: start over, passed a different list publickey,password
debug3: preferred publickey,keyboard-interactive,password
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Offering RSA public key: /home/human/.ssh/id_rsa
debug3: send_pubkey_test
debug2: we sent a publickey packet, wait for reply
debug1: Server accepts key: pkalg ssh-rsa blen 279
debug2: input_userauth_pk_ok: fp SHA256:r+Iix6RkkY64T6pGa6Ko/zzJsrwoG2ry/BY5CvYQsGY
debug3: sign_and_send_pubkey: RSA SHA256:r+Iix6RkkY64T6pGa6Ko/zzJsrwoG2ry/BY5CvYQsGY
debug1: Authentication succeeded (publickey).
Authenticated to localhost ([127.0.0.1]:22).
debug1: channel 0: new [client-session]
debug3: ssh_session2_open: channel_new: 0
debug2: channel 0: send open
debug1: Requesting no-more-sessions@openssh.com
debug1: Entering interactive session. <----------------- 30sec hang
debug1: client_input_global_request: rtype hostkeys-00@openssh.com want_reply 0
debug2: callback start
debug2: fd 3 setting TCP_NODELAY
debug3: ssh_packet_set_tos: set IP_TOS 0x10
debug2: client_session2_setup: id 0
debug2: channel 0: request pty-req confirm 1
debug2: channel 0: request shell confirm 1
debug2: callback done
debug2: channel 0: open confirm rwindow 0 rmax 32768
debug2: channel_input_status_confirm: type 99 id 0
debug2: PTY allocation request accepted on channel 0
debug2: channel 0: rcvd adjust 2097152
debug2: shell request accepted on channel 0
