Haris1977
Install OpenElec in NOOBS (but on usb stick)
Fri Aug 21, 2015 10:05 am
Greetings
I know i can install many os's through NOOBS (like oe, debian etc). But this happens only in sd card. Is there any way to install OpenElec through NOOBS in usb drive? :?:
Re: Install OpenElec in NOOBS (but on usb stick)
Fri Aug 21, 2015 11:18 am
Haris1977 wrote:Greetings
An alternative is Berryboot which has the facility built in
http://www.berryterminal.com/doku.php/berryboot
Thinking outside the box is better than burying your head in the sand...
Haris1977
Fri Aug 21, 2015 12:40 pm
Yes, i know BerryBoot, but you can not update Openelec through its configuration.
So i am looking for a noobs installation (even if it lacks the hdmi cec option i first menu :cry: )
I somewhere read that i only have to manually copy the OS to the flash drive then change the root = statement in cmdline in the boot partition to root=/dev/sda1
Is that true?
kusti8
Fri Aug 21, 2015 1:07 pm
Haris1977 wrote:Yes, i know BerryBoot, but you can not update Openelec through its configuration.
Is that true?
Yes, even with NOOBS, that should be possible. You just have to make sure you change cmdline.txt in the NOOBS menu, not from your computer.
Haris1977
Fri Aug 21, 2015 1:18 pm
Thanks, i will try it asap
