jasonw2012
Edimax EW-7811UTC Help
Fri Aug 07, 2015 11:18 am
I'm a beginner with the raspberry pi 2 B and I also got a Edimax EW-7811UTC wifi adapter, running raspberrypi 3.18.11-v7+ #781 Raspbian, however no matter how much I look on the forums, I just can't get it to work. lsusb detects the device but I don't have the driver installed for it. How can I install the driver and get it working? Any help appreciated!
JimmyN
Re: Edimax EW-7811UTC Help
Fri Aug 07, 2015 1:35 pm
What do you get from the command:
lsmod
In the module column on the left you should see "8192cu" listed.
Then try:
dmesg |grep 8192cu
You should see something like " [ 9.465104] usbcore: registered new interface driver rtl8192cu
MrEngman
Fri Aug 07, 2015 3:50 pm
Try this to install the driver
wget https://dl.dropboxusercontent.com/u/80256631/8812au-3.18.11-v7-781.tar.gz
tar xzf 8812au-3.18.11-v7-781.tar.gz
./install.sh
After installing reboot and then configure you wifi to connect to your network.
MrEngman
MrEngman
Fri Aug 07, 2015 3:52 pm
JimmyN wrote:What do you get from the command:
lsmod
Then try:
dmesg |grep 8192cu
That wifi module does not use the 8192cu driver so he will not see anything about the 8192cu using dmesg.
MrEngman
JimmyN
Fri Aug 07, 2015 4:05 pm
MrEngman wrote: That wifi module does not use the 8192cu driver so he will not see anything about the 8192cu using dmesg.
MrEngman
That's interesting, as that's what all my Edimax EW7811 [Realtek RTL8188CUS] adapters use.
lsusb
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 004: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
Bus 001 Device 005: ID 1997:2433
Bus 001 Device 006: ID 13fe:5200 Kingston Technology Company Inc.
lsmod
ecb                     2279  0
md4                     3587  0
md5                     2045  1
hmac                    3067  1
cpufreq_stats           4433  0
nls_utf8                1443  1
cifs                  310275  2
i2c_dev                 6709  2
snd_bcm2835            21149  3
snd_pcm                90778  1 snd_bcm2835
snd_seq                61097  0
snd_seq_device          7209  1 snd_seq
snd_timer              23007  2 snd_pcm,snd_seq
snd                    66325  11 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device
sg                     21859  0
evdev                  11000  4
joydev                  9766  0
i2c_bcm2708             6200  0
8192cu                569561  0
uio_pdrv_genirq         3666  0
uio                     9897  1 uio_pdrv_genirq
dmesg |grep 8192cu
So I should be using a different driver? The 8192cu has always worked fine for me and it's included in Raspbian.
MrEngman
Fri Aug 07, 2015 4:13 pm
MrEngman
That's interesting, as that's what all my Edimax EW7811 adapters use.
lsusb
lsmod
ecb                     2279  0
md4                     3587  0
md5                     2045  1
hmac                    3067  1
nls_utf8                1443  1
cifs                  310275  2
i2c_dev                 6709  2
snd_bcm2835            21149  3
snd_seq                61097  0
sg                     21859  0
evdev                  11000  4
joydev                  9766  0
i2c_bcm2708             6200  0
8192cu                569561  0
dmesg |grep 8192cu
We are talking about two different wifi adapters.
Your wifi is an Edimax EW-7811Un and yes it uses the 8192cu driver. The wifi the OP is using is an Edimax EW-7811UTC and uses the 8812au/8821au driver, not the 8192cu driver.
MrEngman
JimmyN
Fri Aug 07, 2015 4:18 pm
OK, thanks for the clarification and correction.
jasonw2012
Fri Aug 07, 2015 5:56 pm
MrEngman wrote:Try this to install the driver
./install.sh
MrEngman
I successfully got the driver installed and (after a bit of tinkering with the wpa_supplicant file) got wifi! :D Thank you MrEngman – as well as JimmyN – for replying.
