devenh
sources.list URIs for NTP
Thu Aug 06, 2015 6:56 pm
When I execute
sudo apt-get build-dep ntp
I get a "You must put some 'source' URIs in your sources.list" error.
How does one determine which URI to add? Is there a list?
Here is my sources.list:
deb http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
deb-src http://archive.raspbian.org/raspbian/ wheezy main contrib non-free rpi
devenh
Re: sources.list URIs for NTP
Fri Aug 07, 2015 3:44 pm
As usual, the solution was right in front of me :D
In the sources.list I neglected to follow the instructions appearing in the comments on line #2. Once I ran sudo apt-get update things worked.
