My Raspberry Pi Model B (Samsung chip) suffered damage to its SD slot, causing a repair to be required. I have replaced the SD slot with another, and tested all pins are correct and no shorts have occurred, along with manually connecting the SD detect lines due to the new slot lacking this functionality.
However, when inserting an SD card and attempting to boot, I get the dim ACT light and no response from the Pi. I have checked the FAT portion of the SD, and all appears to be correct so I am willing to assume this is something other than the SD, although please let me know if you believe this not to be the case.
Upon inspecting all my work, I have noticed that R46 and R49 appear to be missing from the board, and I can see traces leading from these two resistors leading to the SD slot, then onto the SoC area. Upon looking at images of other model B Pis I can see these resistors present in these, and am wondering if this could be the reason my system is not reading an SD card? I cannot see any signs of these resistors being pulled off of the board, but please see attached photos to check if I am looking at this incorrectly.
R49:
R46:
SD area overview:
Top board overview:
The bottom pad of the SD has also been lifted during the desoldering of the last slot, but I am led to believe from reading that these are for write protection only and in fact do nothing on the raspberry pi, not even being connected, so I am assuming that this is not the cause of my issues.
Thanks in advance,
Dan
