twlawrenceko
Contact: Yahoo Messenger
No module named spidev?!
Wed Jul 15, 2015 7:20 am
I bought the ic chip mcp3008 for ADC, analog to digital. Using on my sharp ir sensor. But when i was running the code. It showed "Import Error: "No module named spidev" Here is the photo for my troubleshooting, plz help me!
Thanks for any help.
twlawrenceko
joan
Re: No module named spidev?!
Wed Jul 15, 2015 7:58 am
At the top right there is a search box. Enter spidev and press return.
B.Goode
Wed Jul 15, 2015 7:59 am
That error message seems to be telling you that it is not possible to import the spidev python module.
Have you installed that module?
Originally this reply replicated the one from @joan, so the duplicate content has been removed.
twlawrenceko
Thu Jul 16, 2015 3:45 am
joan wrote:At the top right there is a search box. Enter spidev and press return.
I don't see any search box on my desktop, my raspbian is the latest version.
twlawrenceko
sommersoft
Thu Jul 16, 2015 4:23 am
"We mock what we don't understand." - Dr. Trowbridge
twlawrenceko
Thu Jul 16, 2015 4:43 am
sommersoft wrote:
Sorry, what is this for?
I searched for spidev but there's nothing to do.. Did my network got something wrong?
twlawrenceko
sommersoft
Thu Jul 16, 2015 4:50 am
That was the "search in the top right" that joan was talking about. But maybe this will be easier...
search.php?keywords=spidev
https://www.google.com/?gws_rd=ssl#q=sp ... errypi.org
https://www.google.com/?gws_rd=ssl#q=no ... med+spidev
twlawrenceko
Thu Jul 16, 2015 9:41 am
No more solutions?
I searched plenty of spidev, but I tried most of them. But nothing works good on me..
twlawrenceko
joan
Thu Jul 16, 2015 9:54 am
twlawrenceko wrote:No more solutions?
I can't see the point of offering a solution if you have already tried all possible solutions.
twlawrenceko
Thu Jul 16, 2015 10:03 am
I can still try it again, any ideas?
twlawrenceko
Thu Jul 16, 2015 12:14 pm
Mr Sommersoft is using a different skin for the forum, Scroll to the top of the page. Up on the top line, just right of "New Posts" there's a box marked "Search" with a little "magnifying glass" icon
Thu Jul 16, 2015 3:03 pm
supra wrote: Are you using python3.
If yes. Then type sudo python3 <filename>
How will that help? The problem is that the spidev module isn't installed for python3.
The pi user is connected to the spi group so doesn't need sudo to read/write that interface.
sudo pip-3.2 install spidev
may fix the problem.
twlawrenceko
Mon Jul 20, 2015 5:57 am
It doesn't work. It said command not found
twlawrenceko
joan
Mon Jul 20, 2015 6:22 am
pigpio does not use the spidev module. It talks directly to the SPI hardware.
Mon Jul 20, 2015 8:29 am
sudo apt-get install python3-pip
twlawrenceko
Wed Jul 22, 2015 3:31 am
DougieLawson wrote:sudo apt-get install python3-pip
Although this doesn't work for me, but thanks for any help.
sudo apt-get install python-dev python-pip
sudo pip install spidev
I did success, but where's the difference?
http://www.linuxuser.co.uk/news/10-rasp ... des-part-1
twlawrenceko
Wed Jul 22, 2015 8:27 am
Python2 vs Python3
alexey_laa
Thu Jul 30, 2015 7:06 pm
Hello.
I experienced the same problem, but with other module. I installed that module on my Raspberry Pi using PIP. Then tried to use it in IDLE3 shell. I didn't found a way to get my module working and got an error "No module named [...]". But then I found that "import [...]" works normally in IDLE (not IDLE3) shell.
As I understand, there are two versions of Python installed on Raspberry Pi. And PIP tool (and my module, accordingly) was installed for the first version only.
