No sound over HDMI
Posted: Tue Jul 17, 2012 8:25 am
Hi
I have been trying to get my sound to work over HDMI on and off for the last couple of weeks. Nothing seems to make any difference when I use aplay. It appears to play the file but there is no sound. TV is a Panasonic Viera TXL37E30B.
I have tried two HDMI cables and various config.txt settings with no changes. hello_audio.bin 1 works fine.
This morning I decided the only thing left to try was to change the TV to the one from my sons room which is a Currys own brand 15" and without making any other changes I now have sound over HDMI (first part of the Front_Center.wav file is cut off). So what could be wrong with the PanasonicTV?
Below are the results of tvservice on the Panasonic
tvservice -s
tvservice -m CEA
tvservice -m DMT
My output from edidparser
Relevant config.txt settings
I've also tried just
I have also attached my edid.dat file from tvservice -d
Any help would be appeciated.
Cheers
Paul
tvservice -s
state: HPD high|HDMI mode|HDCP off|composite off (0x12001a), 1920x1080 @ 50Hz, progressive
Group CEA has 16 modes:
mode 1: 640x480 @ 60Hz, progressive
mode 2: 720x480 @ 60Hz, progressive
mode 3: 720x480 @ 60Hz, progressive
mode 4: 1280x720 @ 60Hz, progressive
mode 5: 1920x1080 @ 60Hz, interlaced
mode 6: 720x480 @ 60Hz, interlaced
mode 7: 720x480 @ 60Hz, interlaced (native)
mode 16: 1920x1080 @ 60Hz, progressive
mode 17: 720x576 @ 50Hz, progressive
mode 18: 720x576 @ 50Hz, progressive
mode 19: 1280x720 @ 50Hz, progressive
mode 20: 1920x1080 @ 50Hz, interlaced
mode 21: 720x576 @ 50Hz, interlaced
mode 22: 720x576 @ 50Hz, interlaced (native)
mode 31: 1920x1080 @ 50Hz, progressive
mode 32: 1920x1080 @ 24Hz, progressive
Group DMT has 0 modes:
Parsing edid.dat...
HDMI:EDID version 1.3, 1 extensions, unknown aspect ratio
HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
HDMI:EDID found monitor name descriptor tag 0xfc
HDMI:EDID monitor name is Panasonic-TV
HDMI:EDID found monitor range descriptor tag 0xfd
HDMI:EDID monitor range offsets: V min=0, V max=0, H min=0, H max=0
HDMI:EDID monitor range: vertical is 23-61 Hz, horizontal is 15-68 kHz, max pixel clock is 150 MHz
HDMI:EDID monitor range does not support GTF
HDMI:EDID found preferred CEA detail timing format: 1920x1080p @ 50 Hz (31)
HDMI:EDID found CEA detail timing format: 1920x1080p @ 60 Hz (16)
HDMI:EDID established timing I/II bytes are 00 00 00
HDMI:EDID standard timings block x 8: 0x0101 0101 0101 0101 0101 0101 0101 0101
HDMI:EDID parsing v3 CEA extension 0
HDMI:EDID monitor support - underscan IT formats:no, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:2
HDMI:EDID found CEA detail timing format: 1920x1080i @ 50 Hz (20)
HDMI:EDID found CEA detail timing format: 1920x1080i @ 60 Hz (5)
HDMI:EDID found CEA detail timing format: 1280x720p @ 50 Hz (19)
HDMI:EDID found CEA detail timing format: 1280x720p @ 60 Hz (4)
HDMI:EDID found CEA detail timing format: 720x576p @ 50 Hz (17)
HDMI:EDID found CEA format: code 31, 1920x1080p @ 50Hz (native)
HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz (native)
HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
HDMI:EDID found CEA format: code 32, 1920x1080p @ 24Hz
HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz
HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz
HDMI:EDID found CEA format: code 18, 720x576p @ 50Hz
HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
HDMI:EDID found CEA format: code 17, 720x576p @ 50Hz
HDMI:EDID found CEA format: code 2, 720x480p @ 60Hz
HDMI:EDID found CEA format: code 22, 1440x576i @ 50Hz
HDMI:EDID found CEA format: code 7, 1440x480i @ 60Hz
HDMI:EDID found CEA format: code 21, 1440x576i @ 50Hz
HDMI:EDID found CEA format: code 6, 1440x480i @ 60Hz
HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz
HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48 kHz, sample size: 16 bits
HDMI:EDID found HDMI VSDB length 8
HDMI:EDID HDMI VSDB has physical address 3.0.0.0
HDMI:EDID HDMI VSDB supports AI:yes, dual link DVI:no
HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:yes 30-bit:yes DC_yuv444:yes
HDMI:EDID HDMI VSDB max TMDS clock 190 MHz
HDMI:EDID HDMI VSDB content type support: game|cinema|photo|text
HDMI:EDID adding mandatory support for DMT (4) 640x480p @ 60Hz
HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
HDMI:EDID best score mode is now CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 136864)
HDMI:EDID best score mode is now CEA (2) 720x480p @ 60 Hz with pixel clock 27 MHz (score 141472)
HDMI:EDID CEA mode (3) 720x480p @ 60 Hz with pixel clock 27 MHz has a score of 141472
HDMI:EDID best score mode is now CEA (4) 1280x720p @ 60 Hz with pixel clock 74 MHz (score 2710592)
HDMI:EDID DMT mode (4) 640x480p @ 60 Hz with pixel clock 25 MHz has a score of 18432
HDMI:EDID best score mode is now CEA (5) 1920x1080i @ 60 Hz with pixel clock 74 MHz (score 3848832)
HDMI:EDID CEA mode (6) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 120736
HDMI:EDID CEA mode (7) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 120736
HDMI:EDID best score mode is now CEA (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz (score 4973248)
HDMI:EDID CEA mode (17) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 2141472
HDMI:EDID CEA mode (18) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 141472
HDMI:EDID CEA mode (19) 1280x720p @ 50 Hz with pixel clock 74 MHz has a score of 3192160
HDMI:EDID CEA mode (20) 1920x1080i @ 50 Hz with pixel clock 74 MHz has a score of 4307360
HDMI:EDID CEA mode (21) 1440x576i @ 50 Hz with pixel clock 27 MHz has a score of 120736
HDMI:EDID CEA mode (22) 1440x576i @ 50 Hz with pixel clock 27 MHz has a score of 120736
HDMI:EDID best score mode is now CEA (31) 1920x1080p @ 50 Hz with pixel clock 148 MHz (score 5411040)
HDMI:EDID CEA mode (32) 1920x1080p @ 24 Hz with pixel clock 74 MHz has a score of 199532
HDMI:EDID preferred mode remained as CEA (31) 1920x1080p @ 50 Hz with pixel clock 148 MHz
HDMI:EDID has HDMI support and audio support
edid_parser exited with code 0
hdmi_force_hotplug=1
hdmi_drive=2
overscan_top=-20
overscan_bottom=-25
framebuffer_width=1920
framebuffer_height=1080
hdmi_drive=2
hdmi_group=1
hdmi_mode=31
Cheers
Paul
