Wolfiesden
RPi 2 - No sound via HDMI
Sun Jun 28, 2015 5:52 pm
I have a RPi2 with a NOOBS dual boot OSMC/Raspian. HDMI out, nothing in the 1/8" jack.
Under OSMC I have audio out the HDMI just fine. All good there.
Under Raspian, nothing but silence. I have googled for hours and tried everything I can think of. I forced the audio in raspi-config to HDMI. I have scoured the net looking for solutions. Came up dry.
hdmi_drive=2 is present in config and is NOT commented out. Also snd_bcm2835 is present in the modules config as well. I have rebooted several times. Nothing seems to work.
Tried this:
sudo apt-get install alsa-utils
sudo modprobe snd_bcm2835
sudo aplay /usr/share/sounds/alsa/Front_Center.wav
Reports alsa installed already. Still no sound.
Also tried this:
speaker-test -c2 -t wav
No output.
Also tried:
sudo amixer -c 0 cset numid=3 2
Nothing.
Tried MinecraftPi (under X) as well as Micropolis and Quake3. Nothing makes a peep under raspian but when I reboot and select OSMC/Kodi I get lots of sound. So I know its not a cable or defective Pi board. Gotta be a setting or something in raspian.
Any help greatly appreciated.
jpezz
Re: RPi 2 - No sound via HDMI
Sun Jun 28, 2015 8:12 pm
First try it with sudo as it may be a permissions problem. If it works with sudo, is the user in both the audio and video groups? I found I had to add the user to both.
Also, use alsamixer to raise volume to maximum.
Also,
http://elinux.org/R-Pi_Troubleshooting# ... MI_monitor
Wolfiesden
Mon Jun 29, 2015 6:01 am
I did every command with and without sudo before posting here.
I did try the mixer prior to starting this thread and it was 100%. But as an additional test I just took it down to 50%. Exited. Tried both sound tests (nothing). Loaded mixer and took it back to 100%. Tried both tests again. Still nuttin.
Any other suggestions to try?
Oh, that elinux url is one of the pages I hit via google before I posted here.
petoniano
Sat Jul 23, 2016 10:37 am
I have the exact same problem. Did you solve it out?
I had my raspberry pi in my home TV with raspbian and osmc dual boot without any probmems, but now I come to my holiday house and brought my Pi to a different TV, this is a Samsung (my home's LG) and now the sound via HDMI only works in OSMC, not in raspbian.
The only thing I did, was changing the TV.
Anyone can help? thank you.
petoniano
Sat Jul 23, 2016 3:51 pm
Just editing /boot/config.txt
Removing #, from the line:
#hdmi_drive=2
Then reboot
And that's it, easier than expected
