bluesmoke
Error when running yt
Mon Jun 08, 2015 1:13 am
I'm trying to run the youtube-in-commandline tool, yt, but it gives me this error.
pi@raspberrypi ~ $ yt
File "/usr/local/bin/yt", line 9, in <module>
load_entry_point('whitey==0.1', 'console_scripts', 'yt')()
File "/usr/local/lib/python2.7/dist-packages/whitey-0.1-py2.7.egg/yt/__init__.py", line 16, in main
ui.run()
File "/usr/local/lib/python2.7/dist-packages/whitey-0.1-py2.7.egg/yt/__init__.py", line 56, in run
curses.wrapper(self._curses_main)
File "/usr/lib/python2.7/curses/wrapper.py", line 43, in wrapper
return func(stdscr, *args, **kwds)
File "/usr/local/lib/python2.7/dist-packages/whitey-0.1-py2.7.egg/yt/__init__.py", line 100, in _curses_main
self._run_pager()
File "/usr/local/lib/python2.7/dist-packages/whitey-0.1-py2.7.egg/yt/__init__.py", line 174, in _run_pager
feed = self._get_feed(idx, n_per_page)
File "/usr/local/lib/python2.7/dist-packages/whitey-0.1-py2.7.egg/yt/__init__.py", line 141, in _get_feed
self._last_feed = self._feed['fetch_cb'](start, count, self._ordering)
File "/usr/local/lib/python2.7/dist-packages/whitey-0.1-py2.7.egg/yt/__init__.py", line 406, in fetch_cb
return json.load(urllib2.urlopen('%s?%s' % (url, urllib.urlencode(query))))
File "/usr/lib/python2.7/urllib2.py", line 127, in urlopen
return _opener.open(url, data, timeout)
File "/usr/lib/python2.7/urllib2.py", line 407, in open
response = meth(req, response)
File "/usr/lib/python2.7/urllib2.py", line 520, in http_response
'http', request, response, code, msg, hdrs)
File "/usr/lib/python2.7/urllib2.py", line 445, in error
return self._call_chain(*args)
File "/usr/lib/python2.7/urllib2.py", line 379, in _call_chain
result = func(*args)
File "/usr/lib/python2.7/urllib2.py", line 528, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
urllib2.HTTPError: HTTP Error 410: Gone
pi@raspberrypi ~ $
I'm not sure whats going on here, it worked perfectly fine before I re-flashed my sdcard.
Re: Error when running yt
Mon Jun 08, 2015 10:00 am
Google & YouTube API changes broke whitey.
You should search the forum before posting.
Mon Jun 08, 2015 10:52 am
bluesmoke wrote:I'm trying to run the youtube-in-commandline tool, yt, but it gives me this error.
ui.run()
self._run_pager()
pi@raspberrypi ~ $ b
viewtopic.php?f=35&t=109705&p=764977
Joe Schmoe
Mon Jun 08, 2015 12:12 pm
DougieLawson wrote:Google & YouTube API changes broke whitey.
YouTube API changes.
Whitey broken. Blame Google.
Forum search then post.
(Yes, the first line is 6, but it happens sometimes...)
