devenh
cgps/xgps not connecting to Bluetooth GPS
Fri Jun 05, 2015 9:20 pm
Trying to connect my Raspberry Pi 2 B to an XGPS150a Bluetooth GPS. Running latest Raspian. Followed the instructions on how to connect to a Bluetooth device available on a few web pages and I have been able to get to the point where the following command works:
cat /dev/rfcomm0
So I have a connection to the GPS, but I can't seem to get cgps or xgps to connect. I've tried variations of this:
cgps /dev/rfcomm0
but still no go. I'm a newbie, so it is probably something simple that I've overlooked.
Thanks!
devenh
Re: cgps/xgps not connecting to Bluetooth GPS
Sun Oct 02, 2016 3:05 am
I have not been able to get a reliable connection to the XGPS150a, but here are a few things to try:
Turn the XGPS150a on and make sure it is set to Andriod (as opposed to iPhone) mode.
On the Raspberry, run the following command:
hcitool scan
You should see the XGPS150a and an address in the form of XX:XX:XX:XX:XX:XX
Now try:
sudo rfcomm connect XX:XX:XX:XX:XX:XX 0 &
Wait 20-40 seconds and you should hopefully see a connection response.
Now you can enter:
cat /dev/rfcomm0
If you are lucky, you'll see the output from the GPS device.
Search on "raspberry gps rfcomm" for more information. I'd love to be able to get this working consistently, but so far no joy.
bensimmo
Sun Oct 02, 2016 8:10 am
Do you get anything from gpsmon ?
