greeter.ui modified not able to login anymore
Posted: Wed Jun 03, 2015 2:06 pm
by Boff
Hey all,
i did a huge mistake by modifying my greeter.ui. I can´t access my pi anymore. The whole screen is blinking :shock: ALT+CTRL F3 or F2 or F1 are not working. SSH is not activiated yet. What can i do? I don´t want to lose my configuration. Does anybody knows how i can repair this? I already tried to use my windows pc to read the SD-Card, but i wasn´t able to locate the greeter.ui file to substitute it.
Re: greeter.ui modified not able to login anymore
Posted: Thu Jun 04, 2015 12:09 am
by AndyD
One way to access the files is to put the Raspberry Pi into single user mode by adding init=/bin/sh to cmdline.txt.
Another way is to get another SD-card and use that to boot your Raspberry Pi and then mount your original SD-card using a card reader.
Another way is to get a live Linux CD and boot your PC into Linux and use that to mount the SD-card.
Posted: Thu Jun 04, 2015 2:42 pm
by slawekw79
This tutorial should help you
viewtopic.php?f=28&t=112135
