DaPizzaMan
Motion not available from anything other than localhost.
Sat May 30, 2015 10:26 am
I have installed motion on my raspberry pi many times, but every single time I try it from something that is not the Pi, it doesn't even try to load the web page. Please help! :(
DaPizzaMan
Re: Motion not available from anything other than localhost.
Sat May 30, 2015 8:09 pm
I have set webcam_localhost and control_localhost to off, but I still cannot view the webcam from anything else. Would installing an older version of motion work, perhaps?
martyn
Sun May 31, 2015 6:38 pm
A few things to check:
1. Does the location where the image files are saved actually exist (usually /tmp/motion)
2. Are you adding the 'port number' to the web browser (e.g. 192.168.2.5:8081)
3. Is the image size a multiple of 16?
You can also check the files with less /var/log/messages and less /var/log/syslog (you should go to the bottom of each page, the second might offer you an explanation of error messages).
Hope this helps (btw, I am only a motion user, no programming experience etc).
Martyn.
