Hello together,
I've recently bought a Raspberry Pi 2 Model B in combination with an Acer 272HL touchscreen monitor.
Unfortunately, the touchdevice doesnt work - the usb device wont be recognized.
The used OS is Raspbian and the last update was today. The usb cable is directly connected to the raspberry (no usb-hub between).
My lsusb ouput is:
Bus 001 Device 013: ID 2109:2811
I am not very familar with the lsusb output, but as far as I know, it means, that there are no drivers found.
My output from /var/log/messages is, when I plugin the usb cable from touchdevice:
May 28 20:42:48 raspberrypi kernel: [ 1324.867370] usb 1-1.5: New USB device found, idVendor=2109, idProduct=2811
May 28 20:42:48 raspberrypi kernel: [ 1324.867404] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
May 28 20:42:48 raspberrypi kernel: [ 1324.867422] usb 1-1.5: Product: USB2.0 Hub
May 28 20:42:48 raspberrypi kernel: [ 1324.867439] usb 1-1.5: Manufacturer: VIA Labs, Inc.
May 28 20:42:48 raspberrypi kernel: [ 1324.868583] hub 1-1.5:1.0: USB hub found
May 28 20:42:48 raspberrypi kernel: [ 1324.869001] hub 1-1.5:1.0: 4 ports detected
May 28 20:42:49 raspberrypi kernel: [ 1325.164237] usb 1-1.5.1: new full-speed USB device number 14 using dwc_otg
May 28 20:42:49 raspberrypi kernel: [ 1325.654138] usb 1-1.5.1: new full-speed USB device number 15 using dwc_otg
May 28 20:42:50 raspberrypi kernel: [ 1326.144148] usb 1-1.5.1: new full-speed USB device number 16 using dwc_otg
May 28 20:42:50 raspberrypi kernel: [ 1326.654144] usb 1-1.5.1: new full-speed USB device number 17 using dwc_otg
Detailed output from the usb bus port:
lsusb -D /dev/bus/usb/001/013
Device: ID 2109:2811
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.10
bDeviceClass 9 Hub
bDeviceSubClass 0 Unused
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idVendor 0x2109
idProduct 0x2811
bcdDevice 90.90
iManufacturer 1
iProduct 2
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0 Unused
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 12
Output from dmesg:
[ 1944.621469] usb 1-1.4: new high-speed USB device number 18 using dwc_otg
[ 1944.723401] usb 1-1.4: New USB device found, idVendor=2109, idProduct=2811
[ 1944.723422] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1944.723434] usb 1-1.4: Product: USB2.0 Hub
[ 1944.723446] usb 1-1.4: Manufacturer: VIA Labs, Inc.
[ 1944.724549] hub 1-1.4:1.0: USB hub found
[ 1944.725002] hub 1-1.4:1.0: 4 ports detected
[ 1945.021675] usb 1-1.4.1: new full-speed USB device number 19 using dwc_otg
[ 1945.111655] usb 1-1.4.1: device descriptor read/64, error -71
[ 1945.311730] usb 1-1.4.1: device descriptor read/64, error -71
[ 1945.511663] usb 1-1.4.1: new full-speed USB device number 20 using dwc_otg
[ 1945.601635] usb 1-1.4.1: device descriptor read/64, error -71
[ 1945.801655] usb 1-1.4.1: device descriptor read/64, error -71
[ 1946.001609] usb 1-1.4.1: new full-speed USB device number 21 using dwc_otg
[ 1946.421404] usb 1-1.4.1: device not accepting address 21, error -71
[ 1946.511682] usb 1-1.4.1: new full-speed USB device number 22 using dwc_otg
[ 1946.931430] usb 1-1.4.1: device not accepting address 22, error -71
[ 1946.931806] usb 1-1.4-port1: unable to enumerate USB device
I hope you can help me. I dont know, what else I can do.
