Re: Set Static IP address but also getting Dynamic
Wed Oct 28, 2015 10:00 pm
Use the which command and the dpkg command.
ds18s20
Thu Oct 29, 2015 1:57 pm
Got it. dpkg --list did it for me. Thanks:
ii  isc-dhcp-client                       4.2.2.dfsg.1-5+deb70u6                 armhf        ISC DHCP client
Thu Oct 29, 2015 2:08 pm
That's not dhcpcd5. That's the old package that was superseded by dhcpcd5.
kez
Sat Oct 31, 2015 9:59 am
This problem was plaguing me for ages. dhcpcd5 simply seems to ignore the interfaces file so you have to set exclusions in the dhcpcd.conf file. Really quick and easy to do.
Try adding the line:
denyinterfaces eth0
to /etc/dhcpcd.conf (change eth0 as required).
No need to make any extra changes in /etc/network/interfaces or uninstall anything.
man dhcpcd.conf for more info.
Sorry if I missed someone else posting this already or within a link to another post.
Kez
htodd
Tue Nov 17, 2015 4:45 pm
You can stop the client from starting at boot by......
# stop the dhcp client service
sudo /usr/sbin/update-rc.d dhcpcd stop
# clean up dhcp leases
sudo rm /var/lib/dhcp/*
# disable the service from running at startup
# you could substitute remove for disable if you like ot remove it permanently
sudo /usr/sbin/update-rc.d dhcpcd disable
reboot
hdoucet
Tue Feb 09, 2016 9:07 pm
For more information on setting IP addresses in RASPBIAN JESSIE "LITE" ..
See https://wiki.archlinux.org/index.php/dh ... ic_profile
AndyWhittaker
Wed Mar 02, 2016 10:25 am
hdoucet wrote:For more information on setting IP addresses in RASPBIAN JESSIE "LITE" ..
Thanks, that worked for me.... I thought I was going crazy!
Andy
Andy Whittaker
Macclesfield, UK
http://www.ecufix.com/
flyvert
Mon Mar 07, 2016 10:59 pm
THANKS!!!
If the tractor overturns, hold the steering wheel - do not jump!
Henry Sprog
Wed Apr 20, 2016 6:15 pm
Hi all
This has been driving me nuts. However if I had just read the manual page of dhcpcd.conf and its quite straight forward. For some reason setting a static address in interfaces has no effect apart from creating a static and DHCP ip addresses. To get over this you need to edit the file /etc/dhcpcd.conf and add the following to the bottom of the file:
interface eth0
static ip_address=192.168.0.7/24 # static address you want the pi to have
static routers=192.168.0.1 # the address of your dhcp server (normally your router)
static domain_name_servers=192.168.0.1 # same as above so it can use a DNS service
This will stop the DHCP server trying to obtain a lease and instead will use the static address with an infinite lease time.
Still you learn something new everyday. Today it was that you can have one interface with multiple addresses.
Hope this helps?
dubakdubak
Mon Apr 25, 2016 10:52 am
this is driving me totally insane. How can it be so difficult to set just the static IP on the raspberry pi?
I've tried everything (disabling/deleting dhcpcd, dhcpcd5, raspberrypi-net-mods , isc-dhcp-client isc-dhcp-common ) and pretty much everything mentioned in this forum also concerning /etc/networking/interfaces
I've also tried the "nodhcp" in /etc/dhcpcd.conf
Whatever I do, I always end up with some bogus IPv6 address on my eth0, which I see in ifconfig
My /etc/network/interfaces looks like this:
iface eth0 inet manual
address 192.168.3.155
netmast 255.255.255.0
network 192.168.3.0
broadcast 192.168.3.1
gateway 192.168.3.1
But whatever I write in /etc/network/interfaces is just ignored.
I'm really desperate!!
KLL
Mon Apr 25, 2016 1:27 pm
dubakdubak wrote:How can it be so difficult to set just the static IP on the raspberry pi?
for some time now we use for static IP:
example i want for my RPI2: 102 ethernet cable, and 202 WIFI
sudo nano /etc/dhcpcd.conf
interface eth0
static ip_address=192.168.1.102/24
static routers=192.168.1.1
static domain_name_servers=192.168.1.1
interface wlan0
static ip_address=192.168.1.202/24
static domain_name_servers=192.168.1.1.
i still do change the
sudo nano /etc/network/interfaces
auto lo
iface lo inet loopback
allow-hotplug wlan0
iface wlan0 inet manual
wpa-ssid "aaaa"
wpa-psk "xxxx".
#    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
but only to fix the SSID there instead at wpa
but if possible use better dhcpcdui from desktop desktop
hippy
Mon Apr 25, 2016 3:15 pm
dubakdubak wrote: My /etc/network/interfaces looks like this:
If you want to set a static IP address in /etc/network/interfaces you need "iface eth0 inet static", but you may also need to prevent dhcpcd from also getting an IP address.
Or, the recommended way for most cases, is to use "iface eth0 inet manual" and then set the static IP address through dhcpcd configuration, not in /etc/network/interfaces.
cpc464
Fri Apr 29, 2016 10:38 am
I also had the two IP addresses on the same interface problem. In case it helps anyone, this fixed it for me:
# systemctl disable dhcpcd.service
Synchronizing state for dhcpcd.service with sysvinit using update-rc.d...
Executing /usr/sbin/update-rc.d dhcpcd defaults
Executing /usr/sbin/update-rc.d dhcpcd disable
insserv: warning: current start runlevel(s) (empty) of script `dhcpcd' overrides LSB defaults (2 3 4 5).
insserv: warning: current stop runlevel(s) (0 1 2 3 4 5 6) of script `dhcpcd' overrides LSB defaults (0 1 6).
Followed by a reboot. "ip addr" before and after showed that eth0 had the two IP addresses before (DHCP and static) but just one after (static), which is what I wanted. Also during the reboot I monitored the log on my BT Home Hub. Whereas before it would report DHCP requests from the Pi, none were reported after the change. Also after the above change, the dhcpcd daemon was no longer running.
Unix engineer since 1989
shinnra
Fri Nov 04, 2016 10:36 am
I just went back from ArchLinux to Raspbian (lite version) and that was annoying as this was messing my pi router. My solution was to disable dhcpcd service:
systemctl stop dhcpcd
and then create template service:
/etc/systemd/system/[email protected]:
[Unit]
Description=DHCPCD service for %I
Wants=network.target
Before=network.target
BindsTo=sys-subsystem-net-devices-%i.device
After=sys-subsystem-net-devices-%i.device
[Service]
Type=forking
PIDFile=/run/dhcpcd-%I.pid
ExecStart=/sbin/dhcpcd -q -b %I
ExecStop=/sbin/dhcpcd -x %I
[Install]
WantedBy=multi-user.target
this way I can do something like this:
systemctl enable [email protected]
systemctl start [email protected]
and dhcpcd will request IP only for eth0
Human_Robot
Sat Nov 26, 2016 3:15 pm
I fought the static IP battle for a while, I used the nodhcp in /etc/dhcpcd.conf and added the static settings in /etc/network/interfaces
I would get a 169.X.X.X address (instead of the 192.168.X.X address I tried to use)
The fix was to leave off the network X.X.X.X and broadcast X.X.X.X setting in interfaces. Using these settings always seemed unnecessary to me since the OS should be able to figure them out without you defining them.
Do not use network X.X.X.X
Do not use broadcast X.X.X.X
Hope this helps,
ds18s20
Wed Dec 07, 2016 4:04 pm
So it sounds like either disable dhcpd5 or even remove its package, then interfaces would behave as expected for static config scenarios
yiannistamv
Thu Aug 10, 2017 10:57 am
macaan wrote:
Mon Jun 08, 2015 11:23 am
klavo wrote:Hi All,
Code this
auto lo
auto eth0
# allow-hotplug eth0
address 192.168.x.x
netmask 255.255.255.0 # or netmask 24
gateway 192.168.x.x # note the change from gatway to gateway
# auto wlan0
replace x with your network ip scheme.
ok code this where sorry for the dum questio i am a newbie
Thu Aug 10, 2017 11:15 am
Go to the top of /etc/network/interfaces and read the first five lines. Then restore /etc/network/interfaces to the backup copy you took before editing it and go and put the static IP address stuff in your /etc/dhcpcd.conf file.
There's a gazillion posts on this forum on how to do that.
