KevinGriffioen
Permission Issue
Wed May 27, 2015 5:49 pm
I'm literaly facing my last problem on this project I'm working on. If this gets out of the way, my project is done. So please help.
I programmed every code and it al works when I use "sudo python motor.py". As you probebly figure, it turn a motor on and off.
When I press a button on a html page I wrote, It opens the file, excecutes the code and stops at line 13.....
Then my server gives the error you see in the attachment:
http://1drv.ms/1LIw1CE
How can I solve this ? I would like to keep using rpi.GPIO instead of WiringPi op Pigpio
Last edited by KevinGriffioen on Wed May 27, 2015 5:59 pm, edited 1 time in total.
Laurens-wuyts
Re: Permission Issue
Wed May 27, 2015 5:58 pm
Try to add the www-data user to the sudoers file for python:
sudo visudo
Add at the end:
www-data ALL=NOPASSWD: /usr/bin/python
Laurens
Wed May 27, 2015 7:27 pm
That is an enormous security hole that you've just opened.
Use pigpiod it is much better because it moves the stuff that needs root access to the pigpio daemon and the web server userid doesn't need any special permissions.
