Canedje
wget command not working
Sat May 23, 2015 9:53 pm
I do try to run next command:
sudo wget https://dl.dropboxusercontent.com/u/80256631/mt7601-3.18.11-v7-776.tar.gz
I do get the error :
sudo: wget: command not found
What is going wrong?
it looks like the wget command is not known?
the /usr/bin/wget is not there?
I tried install wget:
sudo apt-get install wget
Pakketlijsten worden ingelezen... Klaar
Boom van vereisten wordt opgebouwd
De status informatie wordt gelezen... Klaar
wget is reeds de nieuwste versie.
0 pakketten opgewaardeerd, 0 pakketten nieuw geïnstalleerd, 0 te verwijderen en 4 niet opgewaardeerd.
But says its there allready
Re: wget command not working
Sat May 23, 2015 10:02 pm
Try installing it with
Canedje
Sat May 23, 2015 10:03 pm
DougieLawson wrote:Try installing it with
I mjust did.
It already exist it says
Sat May 23, 2015 10:09 pm
So what does
which wget
show?
What does
export | grep PATH
show?
B.Goode
Sat May 23, 2015 10:12 pm
Why is it necessary/desirable to execute this with sudo?
What is the result of the commands
which wget
echo $PATH
Canedje
DougieLawson wrote:So what does
which wget
show?
What does
export | grep PATH
show?
which wget shows nothing
export | grep PATH sows:
declare -x PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games"
Sat May 23, 2015 10:14 pm
What happens if you log out and log back in?
Canedje
Sat May 23, 2015 10:18 pm
DougieLawson wrote:What happens if you log out and log back in?
No change
wget is not in /usr/bin/
If I try to install it says it already exist
The command is not running
Is there a possibility to uninstall wget and try to install it again?
kusti8
Sat May 23, 2015 10:21 pm
No change
You could try:
sudo apt-get purge wget
Canedje
Sat May 23, 2015 10:26 pm
kusti8 wrote:
No change
You could try:
This worked!
Sun May 24, 2015 5:01 am
Also
sudo apt-get --reinstall install wget
should have worked too.
I'm glad you got it fixed but it is very odd that it went missing. Be on the look out for other odd things on your Pi. Make sure you have changed the default password of the "pi" user, especially if the Pi is connected to the internet at all.
Canedje
Sun May 24, 2015 7:23 am
rpdom wrote:Also
Thanks for the advice
