Onira
Fresh raspbian on RPi2 mocp volume
Tue May 19, 2015 11:02 am
I'm having troubles with mocp
I can't change volume
Cogito ergo sum
Re: Fresh install on RPi2 mocp volume
Tue May 19, 2015 11:08 am
And what is the "Museum of Contemporary Photography" doing with your RPi? They should be stopped.
This is a doctor free zone.
Onira
Tue May 19, 2015 11:14 am
I ment moc - music on console :D
Cogito ergo sum
Tue May 19, 2015 11:26 am
Have you tried the amixer command or the alsamixer command line GUI?
Onira
Tue May 19, 2015 11:35 am
$ amixer
Simple mixer control 'PCM',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined penum
  Playback channels: Mono
  Limits: Playback -10239 - 400
  Mono: Playback -1982 [78%] [-19.82dB] [on]
I thought RPi has stereo :shock:
Cogito ergo sum
Tue May 19, 2015 11:42 am
[email protected] ~ # amixer cget numid=1
numid=1,iface=MIXER,name='PCM Playback Volume'
  ; type=INTEGER,access=rw---R--,values=1,min=-10239,max=400,step=0
  : values=-1475
  | dBscale-min=-102.39dB,step=0.01dB,mute=1
Onira
Tue May 19, 2015 11:48 am
$ amixer cget numid=1
  : values=-1982
Cogito ergo sum
Tue May 19, 2015 12:05 pm
Try increasing that value with a amixer cset command.
Onira
Tue May 19, 2015 12:15 pm
I will try that
but I never had any issues with my previous RPi
Even if I can increase volume via amixer cset, mocp's shortucts do not work :?
Cogito ergo sum
Onira
Re: Fresh raspbian on RPi2 mocp volume
Wed May 20, 2015 5:55 am
I have noticed that on my old RPi (B ver1) new SD card with latest raspbian doesn't work too :(
Cogito ergo sum
Onira
Thu May 21, 2015 5:13 am
Switched to USB audio card and now I can change volume up and down :D
Cogito ergo sum
