Digitizer...
Posted: Thu May 14, 2015 8:50 pm
I ordered a video board which works perfectly fine with the HP monitor. I also have performed some soldering to a generic USB that connects the digitizer board to the glass panel. However, the issue I have is the touchscreen does not work.
Here is what I found in terminal of what I am experiencing:
[ 1136.142151] usb 1-1.4: new full-speed USB device number 15 using dwc_otg
[ 1136.245561] usb 1-1.4: New USB device found, idVendor=1926, idProduct=0dbc
[ 1136.245586] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1136.245603] usb 1-1.4: Product: Touchscreen
[ 1136.245620] usb 1-1.4: Manufacturer: NextWindow
[ 1136.252810] hid-generic 0003:1926:0DBC.0005: hiddev0,hidraw2: USB HID v1.11 Device [NextWindow Touchscreen] on usb-bcm2708_usb-1.4/input1
I am assuming there are drivers that are needed for this board, however I do not have enough knowledge to compile drivers and what not... Any suggestions for my half way finished project would be awesome!!
Also I am running Raspian if that helps a little.
Thanks again for all of the replies,
Mike
Mike
